GTA Tile Shower Installation Guide 2026: Waterproofing, Tile Selection, and Grout
Tile Shower Installation for GTA Homes 2026
A properly built tile shower should last 20-30+ years. A poorly built one fails in 2-5. The difference is entirely in the substrate and waterproofing. Here is what you need to know.
Why Tile Showers Fail
  • Absent or inadequate waterproofing membrane (most common)
  • Wrong substrate material (standard drywall or greenboard in wet areas)
  • Grout cracking at changes of plane (should be caulked, not grouted)
  • Drain flange leakage or improper slope to drain
Waterproofing Options
System Cost Premium Notes
Schluter KERDI membrane $300-600 Industry gold standard, fully bonded
RedGard liquid membrane $100-250 Budget option, quality depends on application thickness
Wedi board $400-800 Rigid foam, factory-applied waterproofing
Acrylic shower pan $200-600 Factory base, eliminates floor leak risk
Substrate Requirements
Walls: Cement board (Durock, HardieBacker) is standard. Never use standard drywall or greenboard in direct-wet areas.
Floor: Mortar bed (traditional, provides custom slope) or Schluter KERDI-SHOWER-ST pre-sloped tray (faster installation).
Tile Selection
Walls: Any glazed ceramic or porcelain. Large format (12x24 or 24x24) is trending — fewer grout lines.
Floor: Minimum COF 0.6 wet (ANSI A137.1). Mosaic tiles (2x2 or smaller) are most slip-resistant.
Grout and Caulk
Epoxy grout (Laticrete SpectraLOCK, Mapei Kerapoxy): Stain-resistant, waterproof, virtually maintenance-free. 2-3x cost of cement grout. Recommended for GTA showers.
Silicone caulk: All changes of plane (floor-to-wall, inside corners, around fixtures) must be caulked — never grouted.
Cost Guide
Scope Cost
Standard tile shower (48x36, ceramic) $4,000-8,000
Walk-in shower (60x36, porcelain, KERDI) $7,000-15,000
Custom large-format with niche and bench $12,000-25,000
Ask tile shower questions on home.renovation.reviews.
LF Builders installs tile showers across the Greater Toronto Area. lfbuilders.ca
