GTA Structural Renovation 2026: Load-Bearing Walls, Beams, and What It Costs
Open-Concept Structural Work in the GTA: The 2026 Reality
Opening enclosed floor plans by removing walls remains among the most popular GTA renovations. Here is what homeowners need to know.
Is the Wall Load-Bearing?
Signs it IS load-bearing:
  • Runs perpendicular to floor joists (check basement ceiling)
  • Sits above a beam, post, or foundation wall below
  • Runs through the same location on multiple floors
  • Has a doubled top plate
Signs it probably ISN’T:
  • Runs parallel to floor joists
  • No support visible below it in the basement
  • Second-floor partition above another room (not above exterior wall or main beam)
Rule: Always confirm with a structural engineer before removing any wall you are uncertain about. Engineer consultation: $500-$1,500. Cheap insurance.
The Beam: Where Costs Vary
LVL (Laminated Veneer Lumber): Standard for most GTA residential spans. Engineer specifies size.
Steel I-beam: Required for longer spans (12+ feet) or where LVL would be too deep.
Flush vs. dropped: Flush beam (hidden in ceiling) = flat ceiling, higher cost. Dropped beam = visible below ceiling, lower cost.
2026 GTA Cost Ranges
Project Cost
Remove non-load-bearing partition $2,000-$5,000
Remove load-bearing wall, flush beam (single storey) $8,000-$18,000
Remove load-bearing wall, multi-storey point loads $18,000-$40,000
Full open-concept main floor (multiple walls + rear bump) $45,000-$90,000
Includes structural engineer, beam, posts, patching, and finishing
LF Builders – structural renovation expertise since 1974: lfbuilders.ca
home.renovation.reviews | Samm Simon 251 KM: sammsimon.ca
