GTA Smart Home Integration and Rough-In Wiring Guide 2026
Smart Home Integration and Pre-Wiring Guide for GTA Renovations 2026
Smart home technology is now a standard expectation in GTA renovations. The most important decisions happen before the drywall goes up. Here is what to pre-wire and what systems to specify.
Pre-Wire During Renovation (Non-Reversible Decisions)
Before closing walls, rough-in:
  • Structured media cabinet (SMC): Central hub for router, network switches, patch panel. Location: basement or main floor mechanical room. Size: 18 or 28-inch rack.
  • Cat6 ethernet: Every room — minimum 1 drop per 150 sq ft. Living areas: 4 drops. Home office: 2-4 drops.
  • HDMI conduit (1" EMT): TV wall to equipment rack — allows future upgrades without wall opening.
  • In-wall speaker wire (14/2 or 16/2 rated): Ceiling and wall positions to AV rack location.
  • Security camera conduit: From camera mounting points to NVR location.
  • Doorbell conduit: 18/2 wire from doorbell to panel/transformer.
Smart Lighting Systems
Smart switches (Lutron Caseta, Leviton Decora Smart): Replace standard switches — all bulbs become smart. Most reliable in GTA installer experience.
Smart bulbs (Philips Hue): Flexible but requires hub or smart switch for full automation.
Confirm neutral wire availability in switch boxes before purchasing (required by most smart switches).
Smart HVAC
Ecobee, Nest, or Honeywell T9 smart thermostats: app control, occupancy sensing, utility rate optimization. Save 10-23% on heating/cooling costs on average. Ecobee most popular with GTA HVAC contractors.
Security and Access Control
  • Smart door locks: Yale, Schlage, Kwikset Halo
  • Video doorbells: Ring, Nest, Arlo (1080p minimum, night vision)
  • Security cameras: POE (power over ethernet) preferred
  • Smart garage: Chamberlain myQ
Cost Guide
System Installed Cost
Structured pre-wiring (whole home) $2,500-6,000
Smart lighting, whole home (Lutron Caseta) $3,000-8,000
Smart thermostat $300-600
Smart security (4 cameras + doorbell) $2,500-6,000
Full integration (AV, lighting, security, HVAC) $15,000-50,000+
Ask smart home questions on home.renovation.reviews.
LF Builders integrates smart home pre-wiring into all major GTA renovations. lfbuilders.ca
