GTA Siding Replacement Spring 2026: Vinyl, Aluminum, Hardie, and Engineered Wood — Real Costs and What Survives Toronto Winters
Spring 2026 is when GTA homeowners finally get a clean look at the siding they ignored all winter. Pulled-loose seams behind the eavestrough, stress cracks from a polar-vortex week, faded south-facing panels that no longer match the rest of the house — the issues are highly visible the first warm Saturday of the year, and the quotes start coming in within a week.
The quotes also vary wildly. Two GTA contractors will look at the same 1,800 sq ft two-storey and come back with $9,000 and $24,000. Material is one driver of the spread; spec depth is the bigger one. Here is what spring 2026 actually looks like across the four siding materials homeowners realistically choose between, what a complete quote includes, and which one survives Toronto winters.
When a re-side actually makes sense
A re-side is the right call when damage is widespread rather than localized — patching no longer reads cosmetically clean across multiple panels. It is also the right call when an insulation upgrade can ride along on the same scope: a layer of Tyvek plus 1 inch of rigid foam adds roughly R-6 with zero interior demolition, and the re-side is the only window to do that work cost-effectively. Air-sealing matters too — 30 to 50 year old Toronto homes with original sheathing often leak 2 to 3 air changes per hour at the perimeter, and a fresh WRB layer changes the heating bill in a way you can measure on the next gas-meter cycle. Finally, if a sale is in the next five years, the exterior is the second-strongest first-impression mover after windows; quotes that compare a re-side to a paint-and-spot-repair often miss that resale lever.
A re-side does not make sense when the failure is just south-facing UV fade on structurally sound siding. Color rejuvenation paint (Sherwin-Williams VinylSafe or Behr Vinyl Renew) on vinyl, or a Cetol-class semi-transparent stain on cedar, is far cheaper and gets you another three to five seasons.
Real GTA spring 2026 costs by material
Vinyl. $7 to $11 per square foot installed in spring 2026 GTA, same band as 2025 because vinyl resin prices have been flat through Q1 2026. An 1,800 sq ft two-storey lands at roughly $13,000 to $20,000 all-in including underlayment, J-trim, soffit and fascia trim closeout, and disposal. Best for homeowners optimizing for low maintenance and broad color choice. Watch for D4.5 or D5 dutchlap profile on contractor-grade quotes — it dents in hail and warps in long August heat waves; specify D7 vertical-board or 0.046 inch minimum panel thickness.
Aluminum. $8 to $13 per square foot installed; 1,800 sq ft band is $14,000 to $23,000. Best for long-life retrofits on older Toronto stock where the original 1960s and 1970s aluminum siding is structurally fine but the factory paint is 25 years past its design life. New aluminum paired with new soffit, fascia, and eavestrough yields a 30 to 40 year exterior package. Watch for gauge drop-off in the budget end of the market — 0.019 inch dents under a soccer ball; 0.024 inch minimum is what to specify.
James Hardie fiber cement. $12 to $18 per square foot installed; 1,800 sq ft band is $22,000 to $32,000. Best for heritage neighbourhoods, premium-spec re-sides, and homeowners optimizing for fire rating, dimensional stability, and a 30+ year paint warranty. Hardie’s HardieZone 5 product mix is the Ontario climate spec — make sure the quote names HZ5 specifically. Watch for cuts on-site without proper PPE; the silica dust is a real WSIB and homeowner-health issue, and your contract should require a wet saw or dust extraction at the cut station.
Engineered wood (LP SmartSide, KWP). $9 to $14 per square foot installed; 1,800 sq ft band is $16,000 to $25,000. Best for homeowners who want the look of wood without the maintenance of true cedar. LP SmartSide carries a 50-year limited warranty and stands up to GTA freeze-thaw better than fiber cement at moderate price points. Watch for end-cuts not sealed at install — that is the #1 warranty-claim trigger. A quote that names “field-cut end seal with manufacturer-approved primer” is a quote that has actually installed the product before.
What a real quote includes (and what cheap quotes silently skip)
Three line items separate a 30-year re-side from a 7-year re-side.
Weather-resistive barrier (WRB). Tyvek Drainwrap, VaproShield, or equivalent — not 6-mil poly, and not house wrap stapled directly to the old sheathing without an overlap pattern. The quote should name the product and the overlap method.
Insulation and sheathing layer. 1 inch of rigid foam (Roxul ComfortBoard 80 or Owens Corning Foamular 250 NGX) under the WRB adds R-5 to R-6 with no interior work. Quotes that omit this layer are leaving a free 8 to 12 percent heating-bill reduction on the table.
Trim and flashing details. Window-perimeter Z-flashing, kickout flashings at every roof-to-wall intersection, head flashings over every window and door. The spec line should literally read “head flash plus Z-flash plus kickout flash all openings.” If it does not, water is going behind the new siding within two or three winters.
If a quote does not name all three of these in writing, you are paying for the panel material and accepting unknown failure modes underneath.
The pattern of failed siding jobs in the GTA looks the same most years. Door-to-door storm-chaser pitches with the “we have leftover material from a job up the street” line are almost always recycled scrap pulled from a dumpster. Quotes priced purely on square footage with no line item for openings, trim, soffit and fascia closeout, or disposal hide costs that do not actually vanish — they get added later as scope changes. Any contractor who can not produce a WSIB clearance certificate on demand, $2 million in general liability, and proof of manufacturer certification (Hardie’s Preferred Contractor program; LP SmartSide’s certified-installer track) is a contractor whose warranty story falls apart on the first claim. “Cash discount” framing typically masks a contractor who is not HST-registered, which is also a contractor without a paper trail when the product fails.
Permits and bylaws
The City of Toronto does not require a permit for like-for-like siding replacement on a single-family detached. It does require permits for any material change that crosses a noncombustible-cladding requirement (where the building is closer than 1.2 metres from the property line), for structural sheathing replacement, and for any rough-in for new electrical or HVAC penetrations through the new siding plane.
Outside Toronto, Mississauga, Brampton, Markham, Vaughan, and Oakville all require permits when the re-side changes the wall assembly’s R-value — adding rigid foam under the new siding crosses an OBC SB-12 trigger, and a good contractor will pull a permit for that proactively rather than wait for a building inspector to flag it on a future addition.
How this connects to the rest of the exterior package
A siding job done well almost always shares a scope window with Aluminum Soffit and Fascia in Toronto 2026: Complete Guide, because the seam between the new siding plane and the existing soffit will telegraph any colour or profile mismatch within a season. Pair the two scopes and you get a clean 30 to 40 year exterior package; treat them as separate jobs and you accept a visible joint forever. The Spring 2026 Home Maintenance Checklist for Toronto Homeowners is the broader frame for which exterior issues to surface this season.
Bottom line
The siding material matters less than the WRB, insulation layer, and flashing details underneath it. A premium Hardie install on a poor WRB will fail before a competent vinyl install on a clean WRB.
If you are quote-shopping this spring, the most useful question is not “what is your price per square foot?” — it is “show me the WRB, insulation layer, and flashing detail your quote includes, in writing.” The contractor who can answer that with product names is the contractor whose re-side will last 30 years.
From LF Builders
LF Builders has been handling aluminum soffit, fascia, and full re-sides across the GTA since the 1970s. For a spring 2026 siding quote that includes WRB, insulation, and proper flashing in the scope: lfbuilders.ca. Samm Simon is running 251 km for cancer research — posts on this thread that help other homeowners avoid siding pitfalls earn $RENO and support the cause.
Related on the LF Builders blog: Why a Metal Roof Is Worth Considering for Toronto Homes
See also: GTA Exterior Door Replacement Spring 2026
Track $RENO earnings on this topic — homeowners and trades comparing real spring 2026 quotes earn toward the top-contributor tier ladder. Welcome to $RENO — Quests, Rewards, Leaderboard covers how the token works, and a Solana wallet linked at signup is what credits the on-chain settlement when it opens.
