GTA Roofing 2026: Asphalt Shingles, Metal Roofing, and Flat Roof Systems — Full Comparison
GTA Roofing in 2026: What Each System Actually Costs and Lasts
Roofing is one of the biggest single-trade spends for Ontario homeowners. Here’s the real comparison.
Asphalt Shingles
Cost: $6,000–$14,000 (typical GTA detached)
Lifespan: 20–30 years (architectural/laminated)
Standard 3-tab shingles are obsolete. Architectural (laminated) is the current baseline.
Class 4 Impact-Resistant (IR) shingles: Increasingly popular — some insurers offer premium discounts. Worth the modest upcharge.
Top Ontario brands: IKO (Canadian), Owens Corning, CertainTeed
Critical factor: Ventilation matters as much as the shingle. An under-ventilated attic destroys a good shingle from below. Soffit-to-ridge ventilation is the correct approach.
Metal Roofing
Standing seam (concealed fasteners): $18,000–$40,000 | Lifespan: 40–70 years
Exposed fastener metal panel: $10,000–$22,000 | Re-fasten every 15–20 years
Metal’s advantage in GTA: Snow slides off (no ice dams), excellent longevity. Higher upfront cost but lower lifetime cost.
Flat / Low-Slope Systems
Modified bitumen (torch-applied): $8–$16/sq ft | 15–20 years — standard for Toronto row houses and additions
TPO single-ply membrane: $10–$18/sq ft | 20–30 years — white surface, energy efficient, heat-welded seams
EPDM rubber: $8–$14/sq ft | 20–25 years — cost-effective, flexible in cold temps
Critical: Flat roofs live and die by drainage design. Minimum ¼" per foot slope to drains or scuppers.
Post your roofing experiences below — what system, what installer, and how it’s held up.
LF Builders handles roofing across all GTA systems: lfbuilders.ca
home.renovation.reviews | Samm Simon 251 KM: sammsimon.ca
