GTA Renovation 2026: The Complete Bathroom Tile Guide
Tile selection is one of the most consequential finish decisions in a bathroom renovation. Here’s the 2026 guide for GTA homeowners.
Format trends in 2026:
Large format tile (24"×24", 24"×48", 12"×24") continues to dominate GTA renovation. Large format reads as more premium, requires fewer grout lines (less maintenance), and suits the open aesthetic.
Material comparison:
Porcelain: Dominant choice. Dense, low-absorption, frost-resistant (relevant for some applications), available in virtually any size and finish. Recommended for floors, walls, and wet areas.
Ceramic: Lower density, slightly higher water absorption than porcelain. Fine for walls and light-duty floors. Less expensive.
Natural stone (marble, travertine, slate): Premium aesthetics. Requires sealing, more maintenance. Beautiful when properly maintained. Popular in high-end GTA bathrooms.
Glass tile: For accents and feature areas. Not recommended for floors.
Shower floor special consideration: Large format tile on shower floors requires adequate slope to drain and anti-slip surface (minimum R10 slip resistance for residential).
Heated floor under tile: Uncoupling membrane (Schluter Ditra-Heat, Warmup) is the proper substrate for heated tile floors — allows movement, prevents cracking.
Cost ranges for tile (GTA, installed, 2026):
  • Basic ceramic: $8–$14/sq ft
  • Mid-range porcelain: $12–$22/sq ft
  • Premium large format: $18–$35/sq ft
  • Natural stone: $22–$45/sq ft
Tile selection experiences and contractor reviews at home.renovation.reviews. LF Builders — bathroom renovation specialists.
home.renovation.reviews — Canada’s renovation community.
