GTA Home Gym Conversion 2026: Basement, Garage, and Spare Room Builds
Building a Home Gym in the Greater Toronto Area
The GTA home gym trend accelerated post-2020 and shows no signs of slowing in 2026. Whether you’re converting a basement, garage, or spare room, a dedicated fitness space is a high-value addition to any Ontario home.
Space and Ceiling Height Requirements
Minimum recommended space: 10 x 10 ft for solo training. Ceiling height: 8 ft minimum (9 ft preferred for overhead press, pull-up bars, and hanging punching bags). Basements often have 7.5 to 8 ft ceilings — confirm before planning overhead equipment.
Flooring Options
  • Rubber tiles (3/4"): Best for free weights, deadlifts, and heavy equipment. Cost: $3-5/sq ft
  • Horse stall mats (4x6 ft): Most affordable high-durability option
  • EVA foam tiles: Good for yoga, stretching, and bodyweight work — not for heavy drops
  • Rubber rolls: Seamless look, good for large spaces
A 12x14 ft gym space flooring: $500 - $1,000 in materials.
Ventilation and Humidity
Exercise generates significant heat and humidity. Basement gyms need:
  • Standalone 50-70 pint dehumidifier
  • Ceiling fan or exhaust fan
  • Fresh air supply (HRV tap-off or dedicated duct)
Garage gyms need insulated walls, floor insulation, and a mini-split heat pump ($3,500 - $6,000) for year-round use.
Electrical Planning
  • Cardio equipment: dedicated 20A circuit per major machine
  • Commercial equipment: may require 240V
  • Lighting: LED high-bay or shop lights work well and are cost-effective
  • Sound system: dedicated circuit recommended
Mirror Installation
Full-wall mirrors: use safety-backed glass, J-channel at floor, mirror clips at top. Cost: $300 - $900 installed for a 6x8 ft section.
Typical Cost Ranges
Scope Cost
Basic (flooring + lighting + mirrors) $3,500 - $8,000
Full basement conversion $15,000 - $35,000
Full garage conversion with mini-split $20,000 - $45,000
Share your home gym build plans and connect with GTA renovation contractors here on home.renovation.reviews.
LF Builders has been completing basement and garage conversions across the GTA since 1974. lfbuilders.ca
