GTA Home Addition Planning 2026: What You Need to Know Before You Design
Adding square footage to your GTA home is one of the most complex renovation decisions — but also one of the most impactful. Here’s what you need to understand before engaging a designer.
Step 1: Understand your zoning
Before any design work, pull your property’s zoning information from your municipality. Key constraints:
  • Maximum lot coverage: Limits total building footprint as a percentage of lot area (often 35–45% residential)
  • Rear setback: Minimum distance from the back of the house to the rear lot line (typically 7.5m in Toronto)
  • Side setback: Minimum distance from building to side lot line (typically 0.6m–1.2m in Toronto)
  • Maximum building height: Varies by zone
  • Heritage overlay: May apply in some neighbourhoods, restricting exterior changes
Step 2: Understand structural implications
Every addition must connect structurally to the existing home. The existing foundation, walls, and roof must be assessed to understand whether they can support the addition as designed. This is a structural engineering question, not a design question.
Step 3: Choose your addition type
Rear addition: Most common in Toronto. Extends into backyard. Typically most cost-effective way to add square footage.
Second-storey addition: Adds upper floor without touching lot coverage. Higher per-square-foot cost; more disruptive.
Side addition: Works for wide lots. Limited by side setback requirements.
Step 4: Budget realistically
Addition costs in 2026: $350–$650/sq ft for single-storey additions. $450–$750/sq ft for two-storey. These include design, permit, and construction.
Share your addition planning experience — what surprised you, and what advice do you have for others starting this process?
home.renovation.reviews — Canada’s renovation community.
