GTA Heritage and Century Home Renovation Challenges 2026
Renovating Heritage and Century Homes in the GTA: 2026 Guide
The GTA has thousands of century homes — pre-1940 properties that require specialized knowledge to renovate safely and legally. Here is what you need to know.
Common Issues in Pre-1940 GTA Homes
Knob-and-tube wiring: No ground wire, cloth insulation. Cannot be covered with insulation under ESA rules. Requires full replacement — typically $12,000-30,000. Affects homeowner’s insurance.
Galvanized or lead water pipes: Galvanized rusts internally. Lead service connections (pre-1955) must be replaced — City of Toronto has active lead pipe replacement program.
Asbestos: Present in pipe insulation, 9-inch floor tiles, ceiling tiles, drywall compound (1950-1980). Professional testing required before any demolition. Abatement: $2,000-15,000.
Plaster walls: Lime plaster over wood lath — difficult to patch invisibly. Consider skim coat over new drywall for seamless finish.
Rubble stone/brick foundations: Not designed for modern waterproofing. Interior drainage systems often more practical than exterior waterproofing.
Non-standard dimensions: Door openings, stair dimensions, and ceiling heights often require custom millwork.
Heritage Designation in Toronto
Properties on Toronto’s Heritage Register or designated under the Ontario Heritage Act require:
  • Heritage Permit for exterior alterations
  • Typical review time: 4-12 weeks
  • Apply through City of Toronto Heritage Preservation Services
Century Home Budget Rule
Century homes consistently exceed initial budgets by 20-40% due to discoveries. Required contingency: minimum 25-30% of project cost.
Window Replacement
Heritage-designated homes: restoration of original wood windows or replacement with historically accurate profiles required. Non-designated: any Energy Star unit is acceptable. Wood window restoration cost: $600-2,500 per window.
Connect with century home renovation specialists on home.renovation.reviews.
LF Builders has been renovating century homes across the GTA since 1974. lfbuilders.ca
