GTA Driveway Replacement 2026: Asphalt vs. Concrete vs. Interlock
Driveway replacement is a high-visibility, high-impact project for GTA curb appeal. This thread covers costs and material tradeoffs for 2026.
Asphalt
$8-$15/sq ft installed. Typical 2-car GTA driveway (400-600 sq ft): $3,200-$9,000. Seal coating every 3-5 years required in Ontario’s climate. Lifespan: 15-25 years with maintenance. Most budget-friendly option.
Concrete
Broom-finish: $10-$16/sq ft. Exposed aggregate: $12-$20/sq ft. More durable than asphalt but susceptible to salt damage. Use sand or calcium chloride (not road salt) to protect concrete in winter.
Interlock Pavers
Concrete interlock: $20-$40/sq ft installed. Tumbled natural stone: $35-$65/sq ft. Individual paver replacement possible. LF Builders has completed 30,000+ interlock and paving projects across the GTA: https://lfbuilders.ca
Drainage Rules
Ontario municipalities require driveways to drain away from streets and neighbouring properties. Permeable options may be required in some municipalities.
What did your GTA driveway replacement cost? Share contractor experiences below.
