GTA Crawl Space Encapsulation and Waterproofing 2026
Crawl spaces are common in older GTA and Halton homes - and often ignored until they cause serious problems. This thread covers 2026 encapsulation, insulation, and waterproofing.
Why Ontario Crawl Spaces Fail
Unencapsulated crawl spaces experience ground moisture evaporation, summer condensation, and winter freezing. Results: mould on floor joists, rot in sill plates, pest infestation, cold floors above. One of the most underdiagnosed air quality issues in Ontario homes.
Encapsulation Costs
Vapour barrier on floor and walls: $3,000-$7,000. Full encapsulation (sealed barrier, conditioned air supply, dehumidifier): $8,000-$18,000. Transforms crawl space from liability to conditioned zone.
Insulation Options
Spray foam on walls (conditioned space): $4,000-$10,000. Batts on floor joists above: $1,500-$4,000. Spray foam is preferred in Ontario - seals air gaps simultaneously. Batt insulation alone still allows cold air infiltration.
LF Builders handles waterproofing and encapsulation: https://lfbuilders.ca
Share crawl space project experience at https://home.renovation.reviews
