GTA Cabinet Painting vs. Replacement Decision Guide 2026
Painted Cabinets vs. Full Replacement: GTA Kitchen Decision Guide 2026
One of the most common GTA kitchen questions: paint existing cabinets or replace them? Here is the real trade-off breakdown.
Paint/Reface When:
  • Cabinet boxes are structurally sound (drawers working, no moisture damage)
  • Layout is functional — you just want a new look
  • Budget is limited and visual impact is the priority
  • Kitchen was renovated within the last 10-15 years
Replace When:
  • Layout needs to change (island, removed wall, opened floor plan)
  • Particleboard boxes showing moisture damage or delamination
  • Drawer slides and hinges failing throughout
  • Already doing full kitchen renovation (countertops, plumbing)
  • Cabinets are original to a 30+ year old home
What Professional Cabinet Painting Delivers
  • Complete disassembly (all doors and drawers removed)
  • Thorough degreasing, light sanding for adhesion
  • Shellac or bonding primer
  • 2 coats alkyd or waterborne alkyd topcoat (spray-applied)
  • Reassembly with adjusted hinges
Duration: 3-7 days. Lifespan: 5-10 years. Key: Spray application vs. brush/roll is visually apparent — hire a spray specialist.
Cabinet Refacing
Keeps existing boxes, applies new veneer to box faces, replaces all doors and drawer fronts.
More durable finish options than painting. Still limited by original dimensions and layout.
Cost Comparison
Approach Cost (15 lin ft)
Professional cabinet painting $3,500-8,000
Cabinet refacing $8,000-20,000
Semi-custom replacement $10,000-25,000
Full custom kitchen $25,000-50,000+
Best ROI when boxes are sound: Professional painting delivers 80% of the visual impact at 25-40% of replacement cost.
Ask cabinet questions on home.renovation.reviews.
LF Builders handles both cabinet painting and full kitchen renovations across the GTA. lfbuilders.ca
