GTA Basement Waterproofing 2026: Interior vs. Exterior — The Real Comparison
Waterproofing Your GTA Basement: Interior vs. Exterior in 2026
Water infiltration is the #1 structural issue we see in pre-1985 GTA homes. With 2026 spring thaw hitting harder after a wet winter, here’s the definitive breakdown.
Interior Waterproofing Systems
What it does: Manages water after it enters the wall cavity. Routes it to a sump pump.
Components: Interior drain tile (weeping tile inside), sump pit and pump, possibly wall membrane system.
Cost (2026 GTA): $8,000–$18,000 for a typical Toronto semi.
Best for: Homes where exterior excavation isn’t feasible (close lot lines, concrete walkways, mature trees at foundation). Also for newer poured-concrete foundations with minor seepage.
Limitation: Doesn’t stop water at the source — manages the symptom.
Exterior Waterproofing Systems
What it does: Stops water at the source — outside the foundation wall.
Components: Full excavation, waterproof membrane application, drainage board, new exterior weeping tile, clean gravel backfill.
Cost (2026 GTA): $20,000–$45,000 depending on perimeter.
Best for: Block foundations (Etobicoke, Scarborough, North York pre-1960 homes), chronic seepage, homes going through major renovation anyway.
Gold standard — eliminates the problem rather than managing it.
When to Choose Each
  • Isolated crack in poured concrete → crack injection + interior drain tile
  • Block foundation with chronic dampness → exterior waterproofing
  • Full basement renovation planned → add exterior waterproofing to the scope
LF Builders provides free waterproofing assessments across the GTA: lfbuilders.ca
Share your basement symptoms below and we’ll help diagnose. Also: home.renovation.reviews has a dedicated waterproofing case study thread.
Samm Simon runs 251 KM for cancer research: sammsimon.ca
