GTA Basement Waterproofing 2026: Complete Interior vs. Exterior Guide
Ontario clay soil and freeze-thaw cycles make basement waterproofing a priority for GTA homeowners. This thread covers interior and exterior methods, 2026 cost benchmarks, and what to look for in a GTA waterproofing contractor.
Interior vs. Exterior: Which Is Right for Your Situation?
Interior waterproofing manages moisture after it enters the wall - weeping tile, drainage mat, and sump pump systems cost $80-$150/linear foot. Exterior membrane waterproofing stops water at the source and runs $150-$300/linear foot. For active leaks through cracks, exterior is usually the permanent fix. Interior systems are preferred for managing hydrostatic pressure in older homes where full excavation isn’t practical.
Why Ontario Clay Soil Creates Unique Waterproofing Challenges
Southern Ontario’s clay-heavy soil expands when saturated and contracts in dry summers, cycling pressure against your foundation walls. This is why cheap tar-based coatings applied pre-1990 fail - they can’t flex. Modern rubber polymer membranes handle Ontario’s freeze-thaw cycles and are mandatory for a proper job.
2026 Cost Benchmarks
  • Interior drainage system + sump pump: $8,000-$15,000
  • Exterior membrane (semi-detached, full perimeter): $20,000-$35,000
  • Crack injection (single crack, interior): $400-$800
  • Window well installation: $800-$1,500 each
Finding a Qualified Waterproofing Contractor
Ask for proof of WSIB coverage, liability insurance, and a transferable warranty (10+ years). LF Builders has waterproofed basements across the GTA for over 50 years: https://lfbuilders.ca
Share your waterproofing experiences below - what worked, what didn’t.
