GTA Balcony and Rooftop Terrace Waterproofing 2026
Balcony and rooftop terrace waterproofing failures are among the most expensive problems in GTA condos and urban homes. This thread covers 2026 systems and costs.
Why It Fails in Ontario
Ontario freeze-thaw cycles (60+ per year in the GTA) stress any waterproofing membrane. Cracked deck coatings allow water into the structure below. In condos, balcony leaks affect the unit below - major liability.
Waterproofing Systems and Costs
Traffic-grade elastomeric deck coating: $8-$18/sq ft. PMMA liquid applied membrane: $12-$25/sq ft. Hot rubber membrane with protection board: $15-$30/sq ft. Full balcony waterproofing + drain replacement + tile/paver: $15,000-$35,000 for a typical 150-200 sq ft GTA condo balcony.
Rooftop Terrace
Waterproofing system alone: $18-$40/sq ft. One of the most technically demanding applications in Ontario - must handle foot traffic AND Ontario temperature extremes. IRMA (inverted roofing membrane assembly) common in GTA flat roof terrace construction.
LF Builders specializes in waterproofing across all applications: https://lfbuilders.ca
Share your balcony waterproofing experience at https://home.renovation.reviews
