Flat Roof Maintenance and Replacement in Toronto: What Every Homeowner Needs to Know
Toronto has a huge stock of flat-roofed homes — everything from 1950s bungalows with modified bitumen to 1980s row houses with TPO membranes. Maintaining and replacing flat roofs is different from sloped roofs and often misunderstood.
Common flat roof materials in Toronto:
Modified Bitumen (Mod Bit): Most common on older Toronto homes. Two-ply system, torch-applied or self-adhered. Lifespan 15–25 years with proper maintenance. Signs it’s failing: blistering, cracking, pooling water, granule loss.
TPO (Thermoplastic Polyolefin): Common on more recent construction and commercial. White reflective membrane, heat-welded seams. Lifespan 20–30 years. Increasingly common on Toronto residential re-roofing.
EPDM (Rubber): Popular on garages and low-slope extensions. Black, single-ply. Lifespan 20–25 years. Seams and penetrations are the failure points.
GRP / Fibreglass: Used on some higher-end newer homes and roof decks. Very durable, seamless when properly installed.
What to budget for replacement (Toronto 2026):
  • Mod bit re-roof (residential): $8–$14/sq ft
  • TPO installation: $10–$18/sq ft
  • EPDM on garage/extension: $6–$10/sq ft
  • Includes removal of old membrane, inspection of deck, new insulation if needed
The most common mistake: Patching a failing flat roof instead of replacing it. Patches buy 1–2 seasons; a failing membrane needs replacement.
Discuss your flat roof situation with Toronto homeowners who’ve been through it at home.renovation.reviews.
