Finished our Pickering basement: sequence, permits, and the rough-in inspection that almost cost us
We finished our Pickering basement last year — 920 sqft, including a 3-piece bathroom, a home office, and a large rec room. Here is the full account including the inspection moment that could have derailed us.
Pre-start checklist:
Before touching anything, we did: plastic sheet moisture test at 8 locations (all passed — dry slab). Sump pump replaced with new Zoeller M57 plus battery backup (proactive, old pump was 12 years old). Had a structural engineer confirm that the I-joist system overhead could accommodate our planned pot light locations without cutting into the web members.
Permit: Applied through the Durham Region building department. Pickering’s process: application online, plans review took 16 business days, permit issued. We used a designer to draw the plans: $1,800.
The rough-in inspection near-miss:
Our electrician completed the rough-in and called for the ESA inspection. The inspector came, reviewed the work, and flagged that we had a shared neutral (multi-wire branch circuit) from the panel into the basement that was not properly connected — the neutral wire was terminated at the panel but the two associated hot wires were on the same phase (not opposite phases as required for MWBC). This creates a hazard where the neutral carries double current. The ESA required the electrician to come back and correct the panel wiring before they would issue the rough-in sign-off. Add 5 days and the electrician’s return trip cost: $280.
Lesson: The ESA inspection caught an actual hazard. If we had drywalled before the inspection — which I was tempted to do to save time — we would have had to open the ceiling to let the inspector in. The permit process saved us from a worse situation.
Full sequence:
  • Rough-in complete: electrical, plumbing (bathroom below-slab cut and repatch: $3,200), and HVAC branch
  • ESA rough-in inspection: pass (after MWBC correction)
  • Plumbing inspection: pass first visit
  • Insulation (2-inch XPS against concrete walls, batts in stud cavities): installed and inspected
  • Drywall, taping, Level 4 finish
  • Tile bathroom (Schluter system)
  • Flooring (LVP with cork underlay)
  • Trim and doors
  • Final inspection: pass
Total cost: $68,400 (including the bathroom, all permits, and contractor costs).
