Exterior paint on our 1950s Leaside house: lead paint test result, prep process, and total cost
Our Leaside house was built in 1953. Before painting, we had to deal with the elephant in the room for every pre-1978 Ontario home: lead paint.
Lead paint testing: Had a certified firm come out with XRF (X-ray fluorescence) testing — the most accurate method, no sampling required. Results: lead detected in the original layers on all exterior wood trim, window frames, and the original board-and-batten sections. The stucco body had no lead (was re-stuccoed in the 1980s).
What this means for painting: Lead-safe work practices are required under Ontario MOL guidelines. The contractor cannot dry-scrape or sand with power tools (this creates lead dust). Allowable methods: wet scraping, chemical strippers, heat guns below 500°C. All waste must be collected in sealed bags and disposed as hazardous material.
Contractor qualification: We hired a contractor who had taken the RRP (Renovation, Repair, and Painting) training for lead-safe work. Not every painting contractor has this — we asked specifically and one of four bidders walked away when we mentioned lead.
Preparation scope:
  • Chemical stripper on all window frames and trim where paint was significantly built up or peeling (not the entire house — just areas where adhesion was compromised)
  • Wet scrape at problem areas
  • Caulk all trim joints, window perimeters, wood-to-stucco joints (over 60 linear feet of caulk applied)
  • Lead-safe primer on all bare wood (Zinsser Bulls Eye 1-2-3 latex — compatible with topcoat, safer than alkyd options for VOC reasons)
  • Body: Benjamin Moore Aura Exterior, 2 coats, on stucco
  • Trim and windows: Benjamin Moore Aura Exterior in satin, 2 coats
Cost: $14,200 for the full house. The lead-safe premium was approximately $2,400 over a standard project of this size (slower prep, waste disposal, PPE costs).
Three years later: not a peel, not a crack. The proper prep made the difference.
