Encapsulated our crawl space in Guelph — before and after air quality, full cost breakdown
Our 1972 Guelph ranch had a vented crawl space that we suspected was the source of musty odours on the main floor. After a professional assessment, we encapsulated it. Sharing the full process and results.
Assessment findings:
  • Crawl space inspector found visible mould on 30% of the floor joists
  • Existing 6-mil poly (installed maybe 15 years ago) was torn in multiple places
  • Three of the four vents were open year-round
  • Wood moisture content readings: 22 to 28% in the joists (anything above 19% supports mould growth)
What the encapsulation included:
  • Mould remediation on floor joists (borate treatment + HEPA vacuuming): $1,800
  • Remove old poly
  • Install 20-mil reinforced poly barrier on floor, sealed to walls and piers with tape
  • Spray foam all vents closed (sealed permanently)
  • Closed-cell spray foam on foundation walls and rim joists (R-10 to R-12)
  • Installed Aprilaire E100 dehumidifier (crawl-space rated) with drain line
Cost:
  • Mould remediation: $1,800
  • Encapsulation (poly, foam, sealing): $7,400
  • Dehumidifier supply and installation: $1,900
  • Total: $11,100
6-month results:
  • Musty odour: completely gone from main floor
  • Crawl space wood moisture content (re-tested): 11 to 13%
  • Dehumidifier runs significantly less than expected — the encapsulation alone removed most of the moisture load
  • Heating gas bill: down approximately $55/month (the crawl space was a major infiltration path)
Post-encapsulation, a different contractor confirmed the crawl was “one of the better jobs” they’d seen. The mould remediation before encapsulation is the step many companies skip — don’t let them.
