Designing a compact reading nook: 24-inch or 30-inch desk depth?
I am planning a compact reading and content-creation nook in a spare-room alcove and would appreciate some practical design advice.
The space needs to work for three different purposes:
  1. Laying out cards for personal readings
  2. Taking consistent overhead photographs and short videos
  3. Storing several decks, notebooks, lighting equipment and small accessories
The layouts range from a simple three-card row to a larger ten-card Celtic Cross. These are the actual layouts the workspace needs to accommodate:
https://deckaura.com/pages/tarot-spreads
Disclosure: I maintain the linked website. I am sharing the page only because it shows the real table layouts and working area I need to plan around.
I am currently deciding between a 24-inch-deep built-in surface and a 30-inch-deep surface.
The 24-inch option would preserve more walking space, but I am concerned that it may feel cramped once the following are added:
  • A full ten-card layout
  • Space for a notebook
  • A small monitor or tablet
  • An overhead camera mount
  • Two compact lights
  • Room around the cards so the photographs do not feel crowded
The 30-inch option would provide a better working surface, but it would make the room noticeably tighter.
I would appreciate advice on the following points.
Desk depth
Is a 24-inch surface normally sufficient for detailed tabletop work and overhead photography?
Would a 30-inch surface provide a meaningful advantage, or would it mostly create unused space at the back of the desk?
Floating desk or base cabinets
I like the visual simplicity of a floating desk, but base cabinets would provide storage for decks, notebooks and camera accessories.
Would shallow drawer cabinets on one side be a reasonable compromise, or would an open base make the nook feel larger?
Surface material
The surface needs to photograph well without creating strong reflections.
I am considering:
  • Matte laminate
  • Sealed natural wood
  • Microcement
  • A removable fabric or leather desk mat
Which material would be easiest to maintain while still looking good in close-up photographs?
I would prefer a warm neutral finish rather than a very dark or theatrical room.
Lighting
I need soft, even light across the complete desk surface without shadows from my hands or the camera mount.
Would you install:
  • Adjustable wall-mounted lights
  • A ceiling track with movable heads
  • Under-shelf lighting
  • Removable photography lights used only when needed
The room should still feel comfortable when the photography equipment is turned off.
Overhead camera position
I am considering either a wall-mounted articulated arm or a ceiling-mounted camera point.
The wall-mounted option would be easier to adjust, but I am concerned about vibration when the desk is touched.
Has anyone built a compact overhead product-photography station into a home office or craft room?
Storage
I would like the decks to remain accessible without covering the work surface.
Would you use:
  • Shallow drawers
  • Narrow wall shelves
  • Closed upper cabinets
  • A vertical pull-out cabinet
  • A bench with storage beneath it
Some boxes are visually attractive, so a small amount of open display storage would be useful, but I do not want the background to become cluttered.
Electrical planning
The nook will need power for lights, a camera, a tablet and occasional battery charging.
Would you place outlets:
  • Directly above the desk
  • Below the desk with cable grommets
  • Inside a cabinet
  • In a recessed power strip at the rear of the worktop
My main priorities are a clean background, minimal visible wiring and enough usable surface for the larger layouts.
I would be especially interested in photos or examples of compact craft desks, jewellery photography stations, journaling corners or other small workspaces with similar requirements.
For a compact reading nook with the purposes you’ve described, a 30-inch-deep desk would provide more comfortable space to lay out cards and equipment, especially for the larger Celtic Cross layout. A 24-inch depth might feel a bit cramped, especially when trying to take overhead photos or videos. I’d recommend considering the size of your lighting equipment and other accessories to ensure they fit comfortably on the desk, and also think about the height of the desk and any shelving or storage you plan to include.
(If it helps: typical decks & porches ranges are on lfbuilders.ca/costs/deck)
