Choosing Exterior Cladding in Ontario 2026: Vinyl vs Brick vs Fibre Cement vs Stone
Exterior cladding is one of the most visible and weather-critical elements of your home. With Ontario’s freeze-thaw cycles, high-UV summers, and heavy precipitation, material choice matters enormously.
Vinyl siding (PVC)
Cost: $8,000–$18,000 installed for average home
Pros: Low maintenance, colour-stable (modern formulations), good moisture resistance, widely available
Cons: Can crack in extreme cold (-20°C+), lower perceived premium value, limited repairability
OBC note: Must meet CAN/ULC-S134 fire test requirements when adjacent to certain zones
Brick (traditional masonry)
Cost: $25,000–$60,000+ for full re-cladding
Pros: Extremely durable (50–100 year lifespan), fire resistant, premium appearance, adds resale value
Cons: Expensive, requires skilled trades, mortar needs repointing every 20–30 years
Fibre cement (James Hardie, Allura)
Cost: $15,000–$35,000 installed
Pros: Excellent durability, can mimic wood or stucco appearance, Class A fire rated, moisture resistant
Cons: Heavier than vinyl (installation complexity), requires painting every 10–15 years
Natural stone / stone veneer
Cost: $20,000–$55,000+
Pros: Stunning visual impact, extremely durable, unique character
Cons: Most expensive, requires expert installation, heavier structural load consideration
What cladding did you choose for your Ontario home? Share your install experience, contractor quality, and how it’s held up in GTA winters.
home.renovation.reviews — Ontario renovation decisions, community-tested.
