Balcony Waterproofing in Ontario - When It Fails and What Repair Costs
Dealt with a balcony waterproofing failure on my Toronto semi-detached last year. The repair ended up being more involved than expected - posting the details for anyone who spots similar warning signs.
What Tipped Me Off
Water staining appeared on the living room ceiling directly below the second-floor balcony after the spring thaw. I had noticed the vinyl membrane on the balcony was bubbling at the edges for about a year and ignored it. That was a mistake.
What Was Found
When the contractor pulled back the failing vinyl membrane (Duradek-type system, probably 15 years old):
  • Plywood subdecking was saturated and delaminated at the outer 12 inches
  • One joist end was soft with early rot
  • The drip edge flashing had separated from the wall
Scope of Repair
  • Remove failed membrane
  • Replace outer 16" of subdecking (2 sheets partial)
  • Treat exposed joists with borates, sistered the soft joist
  • Install new drip edge and wall flashing integration
  • Install new Duradek vinyl membrane
  • New aluminum trim at perimeter
Cost: $6,400
That balcony is roughly 160 sq ft. Cost would have been $3,500-$4,000 if I had not let the subdecking rot. Lesson: fix bubbling membrane immediately.
Warning Signs to Watch For
  • Bubbling or lifting at membrane seams or edges
  • Cracking or chalking of membrane surface
  • Water staining on ceilings below
  • Soft spots when walking on the deck
  • Visible separation at wall-to-deck transitions
Anyone else navigating a balcony membrane replacement? Particularly curious if anyone has compared Duradek vs fiberglass (FRP) for residential applications.
