Aluminum soffits and fascia in Ontario 2026: signs your fascia is rotting, when you need a permit, and what a proper scope looks like
Most calls about soffit and fascia start the same way: “there’s a gap” or “the aluminum is pulling away.” That’s not the problem. The aluminum is almost never the problem.
The fascia board failure you’re not seeing
Aluminum fascia is a cover, not a structural element. It sits over a wood fascia board, and that board is what rots. The aluminum hides it completely until the rot is severe enough that the board starts to separate from the rafter tails — at which point it’s been going for 2 to 4 years already.
A few things to check before it gets obvious:
Paint blistering or bubbling along the roofline is usually fascia-board moisture wicking up behind the aluminum, not a bad paint job.
Gaps where eavestrough hangers attach to the fascia are almost always board failure. The hanger screw is pulling through wood that’s gone soft.
Soft spots when you press on the aluminum at corners mean the board behind has lost structural integrity.
Staining on the soffit directly below the fascia line is water tracking from a failed fascia-to-rafter-tail joint.
Why the scope is often bigger than expected
Fascia boards sit at the end of the rafter tails — the part of the roof structure that extends past the exterior wall. When moisture reaches the fascia board, it doesn’t stay there. It wicks along the rafter tail and into the sheathing edge.
When we strip aluminum to inspect, we find the rot has moved 12–18 inches up the rafter tails more often than not. At that point the scope is fascia board, rafter tail extensions, and sheathing edge sealing — not just new aluminum. A contractor who won’t strip the existing aluminum before quoting is giving you a number without knowing what’s back there.
When you need a permit
For straightforward aluminum replacements — strip the damaged aluminum, replace the fascia board, reinstall — a permit is not required in most GTA municipalities. That’s maintenance work.
You’re into permit territory when structural rafter tail repairs are part of the scope, when the soffit venting configuration is changing, or when the project is tied to a roof replacement that already has a permit pulled.
Most soffit and fascia jobs in the GTA don’t need one. But if a contractor finds structural damage during strip-out, that has to be flagged before work continues. The right move is to stop, walk the homeowner through what was found, and figure out whether the scope has crossed into permit territory.
Soffit venting — worth checking while you’re in there
The Ontario Building Code requires a minimum net free ventilation area for attic spaces: 1/300th of the insulated ceiling area, with at least 25% near the ridge and 25% near the eaves. On most bungalows, that’s roughly 60 to 100 square inches of net free vent area at the eaves.
Soffit replacement is a good time to check whether you have continuous ventilation or individual panel vents. Continuous perforated soffit moves air more evenly than scattered individual vents and is the standard on most GTA builds from the last 20 years. If your existing soffit has non-perforated panels with vents cut in, switching to perforated continuous soffit at the same time as the fascia work is a low-cost attic moisture upgrade.
What a proper scope looks like
Before pricing, a contractor should strip at least a section of existing aluminum to inspect the fascia board and rafter tail ends. Quoting without stripping is guessing.
The written scope should state whether the fascia board needs replacement, whether the rafter tails are serviceable, and what’s happening at the sheathing edge. It should specify soffit profile (7/8" beaded, solid, or perforated), gauge, and color — aluminum profiles look different against brick vs. siding, so confirm before ordering.
J-channel and F-channel need to be called out specifically. J-channel is the water management piece at the wall-to-soffit interface. Bad J-channel installation is one of the more common ways water gets into the exterior wall assembly and nobody figures out where it came from.
If the eavestrough is coming down as part of the job, the scope should address whether it gets re-hung or replaced, and whether hangers need new drilling into fresh fascia board. This usually comes up on-site when the aluminum is off and the board condition is visible.
We’ve done this kind of work on 30,000+ projects across the GTA over 50 years. For more on exterior water management and how eavestrough work connects to soffit and fascia, there’s a thread with a lot of field detail here: Eavestroughs in Ontario: when repair is enough, and what a good replacement quote actually covers (2026). Contributors who post helpful answers on these topics earn $RENO tokens through the forum’s quest system — details at Welcome to $RENO — Quests, Rewards, Leaderboard.
Watch: Siding renovation shorts
