GTA eavestrough replacement in 2026: seamless vs. sectional, the downspout extension most contractors skip, and what a complete quote includes
Ontario’s freeze-thaw cycle does something specific to sectional eavestrough. Water expands roughly 9% by volume when it freezes. That expansion force pries sectional gutter joints apart a little more each winter – and once a joint opens even slightly, every rainfall after that deposits debris into the gap. By year seven or eight on many GTA homes, sectional eavestrough is holding standing water at every joint. Replacement at that point isn’t optional.
Seamless aluminum sidesteps that entirely. The trough is roll-formed on-site to the exact length of your roofline and cut once. No joint between the corner and the first downspout bracket. Worth knowing before you start comparing quotes.
5" vs. 6" profile: when it actually matters
Most GTA homes were built with 5" K-style eavestrough. For a bungalow with a modest eave run and a downspout every 40 feet, 5" works fine. Upgrade to 6" when:
  • Your roof drains more than 1,000 square feet of area per downspout
  • You have a steeper pitch (6:12 or above) that accelerates runoff
  • A large dormer or valley is channeling extra volume into the run
The installed price difference in 2026 is roughly $5–$6 per linear foot ($8–$13 for 5", $13–$17 for 6", both seamless aluminum, excluding HST). On a 150-linear-foot job, that’s $750–$900 extra for the upgrade. Usually worth it: undersized eavestrough overflows directly behind the fascia board, which is the worst place for water to go.
The downspout extension most contractors skip
Toronto’s municipal guidelines require downspout discharge at least 2 feet from the foundation. Most GTA homes with older eavestrough have extensions that end 6–8 inches from the wall – sometimes shorter, sometimes aimed directly at a window well or basement stairwell.
Ask on every quote: where does each downspout discharge, and how far from the foundation? A quote that just says “install 2 downspouts” without a discharge note is a yellow flag. Push for specifics.
Soffit and fascia: the hidden prerequisite
Eavestrough hangs from fascia. On many GTA homes from the 1970s and 1980s with wood fascia, that board is rotted – sometimes obvious, sometimes hidden behind the existing trough. New eavestrough on rotted fascia fails within three seasons. Ask the contractor to inspect behind the existing trough before the quote is finalized, not after the old material comes down.
Soffit is worth checking at the same time. Missing or damaged soffit panels restrict attic ventilation, and that contributes to ice dam formation in winter – a separate problem with its own costs. We covered both in detail here: GTA aluminum soffits and fascia in 2026.
Gutter guards: when they pay off
GTA’s tree canopy – mostly maples and oaks – drops late in autumn, right into the peak clogging window. If you’re cleaning gutters twice a year and still getting overflows, a micro-mesh guard is worth pricing at the time of replacement. Retrofitting guards the following spring costs noticeably more.
Skip the foam inserts entirely. They hold moisture, degrade in UV, and will eventually sprout plants inside your trough. Not theoretical – it happens.
2026 GTA price ranges
  • Seamless 5" aluminum: $8–$13/ft installed (exc. HST)
  • Seamless 6" aluminum: $13–$17/ft installed (exc. HST)
  • Full package (eavestrough + soffit + fascia): $4,500–$12,000+ depending on footage and fascia condition
  • Gutter guard addition at time of replacement: $4–$8/ft installed (quality micro-mesh)
What a complete quote should specify
  • Seamless vs. sectional (should be seamless)
  • Profile size (5" vs. 6") with reasoning
  • Fascia inspection before work starts
  • Downspout count, location, extension length, and discharge point
  • Gutter guard option (even if not included, it should be offered)
  • Disposal of old material
If anything on that list is missing, ask. The answer usually tells you what you need to know about the contractor.
Track $RENO earnings on this topic – top contributors get tier-up rewards. See the welcome guide to connect your Solana wallet and start earning.
Seamless vs sectional is an easy call honestly — the only reason to go sectional in 2026 is cost, and even then the long-term maintenance usually closes the gap.
The downspout disconnection piece is where I see homeowners leave real money on the table. If you are in Toronto city limits and still draining to the storm/sanitary system, the City’s downspout disconnection program has been running for years and in some cases there are rebates attached. More importantly, if you are applying for the basement flood subsidy, disconnected downspouts are often a requirement or at least factor into the assessment.
On sizing: the standard 4" x 3" downspout that most builders installed is undersized for a large roof area. A good eavestrough contractor will do a load calculation based on your roof square footage and local rainfall intensity. In the GTA we design for about a 1:10 year storm event minimum. If your eavestrough overflows during a heavy rain, the issue is usually undersized gutters, not a blockage.
Worth getting 2-3 quotes and asking each one to specify: gauge of aluminum, K-style vs. half-round, hanger spacing, and the exact downspout count and sizing. These are the variables that separate a 10-year system from a 25-year one.
