Why energy-saving mode doesn’t always reduce your electricity cost
A lot of people think turning on energy saving will reduce the amount they pay for electricity.
Meanwhile all energy saver does is reduce the amount of energy use at a particular time, this means that the electricity would be used bit for a longer period of time.
Many people believe that turning on energy-saving mode will always reduce their electricity bill. In some cases it helps, but it does not always save as much money as people expect.
The condition of appliance also matters. An old fridge or old AC with weak parts will
consume a lot of power even when eco mode is on.
Energy-saver mode often just stretches out consumption over longer periods, canceling out savings. Plus, failing components in old, inefficient appliances will completely negate any settings you try to use.
Energy saving mode helps, but it is not magic. If the appliance is old or overworked, it still uses power in the background sometimes the difference on the bill is barely noticeable.
Watch: Appliances renovation shorts
