Toronto FASTRACK permits 2026: 5–10 day reno approvals
If you’re planning a small renovation in Toronto this spring - a deck, a finished basement, a kitchen rebuild that doesn’t change the footprint - you probably don’t need to wait the standard 6–12 weeks for a building permit. The City’s FASTRACK program can turn around a permit in as little as 5 to 10 business days when your project meets a specific set of rules. Most homeowners (and a surprising number of contractors) don’t realize this exists.
This guide walks through who qualifies, what to prepare before you submit, and where projects most often get bounced out of the fast lane.
What FASTRACK actually is
FASTRACK is a streamlined review path inside Toronto Building for low-complexity residential applications. The program prioritizes projects that are:
  • Under 100 m² of new or altered floor area
  • Fully zoning-compliant (no Committee of Adjustment minor variance required)
  • Single-family, semi, or townhouse properties (most condos and multi-residential do not qualify)
  • Submitted with complete drawings, energy compliance, and structural details on day one
When all of those are true, your application is routed through a faster review queue rather than the general residential queue. The standard residential queue runs 6–12 weeks in 2026 for a clean submission. FASTRACK is closer to 5–10 business days for most approvals.
What kinds of projects fit
In our experience working with homeowners across the GTA, these are the projects most likely to qualify:
  • Interior alterations that don’t move walls in load-bearing locations
  • Basement finishing where ceiling height and egress already meet code
  • Detached garages and accessory structures under the size cap
  • Deck additions where setbacks are clearly inside the zoning bylaw
  • Bathroom renovations that don’t change the building footprint or relocate plumbing stacks
Projects that almost always get bounced out of FASTRACK:
  • Anything triggering Committee of Adjustment (lot coverage, height, setback variances)
  • Heritage properties or properties inside a Heritage Conservation District
  • Second suites or garden suites — those go through the dedicated suite-approval stream, not FASTRACK
  • Anything requiring a Site Plan Control review
What to have ready before you submit
The single biggest reason a “fast” application becomes a slow one is incomplete drawings. Before you submit, you should have:
  1. A Toronto Building application form with all sections filled, including the contractor information if known
  2. Architectural drawings (site plan, floor plans, elevations, sections) prepared by a designer or BCIN-licensed practitioner
  3. Structural drawings sealed by a Professional Engineer for any structural change, including beam replacements or load-bearing wall removals
  4. SB-12 / energy efficiency compliance package for any conditioned-space alterations
  5. Plumbing schedule if any plumbing fixtures are added, moved, or replaced
  6. HVAC heat-loss/heat-gain calculations for any HVAC change
  7. Permit fee deposit — the minimum permit fee in Toronto is $214.79, and interior alterations bill at $11.53 per m²
If even one of these is missing or unsigned, the file gets pulled out of FASTRACK and put back in the standard residential queue.
How to actually submit
Toronto Building applications are filed through the City’s online permit and licence portal. Choose Building → Residential → Small Residential and indicate FASTRACK eligibility on the application checklist. Plan reviewers will confirm eligibility within the first business day; if your project doesn’t fit, you’ll be notified and given the option to withdraw or proceed through the standard stream.
If you’ve never done this before, the City of Toronto Building permit overview is the authoritative starting point — bookmark it.
A realistic timeline
For a fully compliant FASTRACK submission filed Monday morning:
  • Day 1: intake review confirms eligibility
  • Days 2–4: zoning, building, plumbing, HVAC, and energy reviewers run their passes in parallel
  • Days 5–10: any minor revisions are returned for one quick correction; permit issued
Compare that to 6–12 weeks through the standard queue and you can see why understanding this program matters — it can be the difference between starting a basement renovation in early May vs. mid-July.
How this fits with the rest of your project
A faster permit is only useful if everything downstream is ready. That means:
  • Contractor lined up and WSIB-cleared
  • Insurance certificate from the contractor on file
  • Drawings the contractor can actually build from (not just permit drawings)
  • Material orders placed before the lumber pricing window shifts (the GTA tariff and lumber pricing thread covers this in more detail)
Common questions
Does FASTRACK cost more than a regular permit?
No. The permit fee structure is the same — it’s a faster lane, not a paid-priority lane.
Can a homeowner submit themselves, or do you need a designer?
Technically anyone can submit, but most reviewers send back drawings that aren’t BCIN-stamped or PEng-sealed where required. For most homeowners, hiring a designer is faster and cheaper than three rounds of revisions.
What if I’m planning a basement waterproofing or backwater valve install?
That’s a different stream entirely — most flood-protection work is permitted through plumbing rather than building, and many projects qualify for the Basement Flooding Protection Subsidy (up to $6,650 in 2026). Backwater valves do require a permit, but it’s a same-week turnaround through your T94-licensed plumber.
If you’re planning a project this spring and aren’t sure which stream applies, drop the details in this thread and someone here will point you in the right direction. Most GTA homeowners over-estimate how long the permit phase takes — when the project is small and clean, FASTRACK exists for a reason.
For broader context on getting started with a renovation, the forum’s Most Commonly Asked Questions thread covers contractor vetting, contract red flags, and project sequencing.
