Toronto Exterior House Painting 2026: Costs, Prep, Booking
Spring is when most GTA homeowners notice the exterior is tired. The chalk on the south wall, the streaks down the soffit, the trim that did not survive another winter freeze-thaw cycle — they all surface in April and May, exactly when the painters who book up by mid-summer are still taking calls. The cost spread on those calls is wider than most homeowners expect: a “Toronto exterior repaint” can be a $4,000 conversation or a $14,000 conversation, and the difference is rarely the brand of paint. Below is what the spring 2026 numbers actually look like, what changes when the surface is brick vs stucco vs aluminum siding, and where the homeowner-side decisions actually move the price.
Real GTA spring 2026 cost bands by home type
Toronto-area exterior repaints in spring 2026 are running roughly $3.50 to $6.00 per square foot of paintable surface, and that figure includes two coats, normal prep, and clean-up. Translated into whole-house quotes:
  • Bungalow (800 to 1,200 sf footprint): $4,000 to $7,000
  • Semi-detached or townhome (typical GTA brick-front, frame-or-brick sides): $5,500 to $9,000
  • Standard 2-storey detached (1,500 to 2,000 sf footprint): $8,000 to $14,000
  • Larger custom or older 3-storey homes with elaborate trim: $14,000 to $20,000+
Those bands hold across the major Toronto-area painting contractors quoting publicly in spring 2026. The big drivers when a quote sits at the upper end are scaffolding (any time the painter cannot reach a wall safely from a 32-foot extension ladder), wood repair on trim and fascia, and prep on chalking or peeling existing paint. Smooth aluminum siding sits at the cheap end. Heavily textured stucco and porous brick sit at the expensive end.
Surface-by-surface: where the numbers actually come from
Stucco is the most expensive common Toronto exterior to paint, typically $4.00 to $7.00 per square foot, because the texture eats paint, hairline cracks need filling before paint, and stucco repair often surfaces during pressure washing. Acrylic masonry paint is the right product for exterior stucco; standard exterior latex will fail on stucco within 2 to 3 years. If the existing stucco is 2010-or-older and was last painted with oil-based or low-quality acrylic, expect the painter to recommend a bonding primer over the entire surface — that adds $1.50 to $2.50 per square foot but is the single biggest determinant of whether the new paint lasts 8 years or 18 months.
Brick painting runs $1 to $4 per square foot once prep is added, but the prep load varies more on brick than on any other surface. Older Toronto brick — pre-1960s especially — frequently has efflorescence (white salt streaking), failing mortar joints, or moisture issues that paint will trap and worsen if not addressed first. The honest answer on a 1920s Toronto front-porch brick is sometimes “do not paint this; clean and seal it instead.” If brick is being painted because it has been painted before and needs a refresh, the cost is closer to a stucco repaint because the existing layer of paint must be scraped or stripped wherever it has failed, and the painter will need to use a high-flexibility masonry paint that breathes.
Aluminum siding is the cheapest common Toronto exterior to paint: $2.00 to $4.50 per square foot, $3,000 to $7,000 for a typical home. Aluminum is smooth, takes paint quickly, and rarely needs scaffolding because most aluminum-clad homes are post-1970 with reachable rooflines. The two failure modes to watch for: (1) chalk on existing aluminum paint that was not properly washed and de-glossed before recoat, and (2) using interior-grade or low-grade exterior paint, which will fade visibly in 18 to 24 months on south-facing aluminum. A 100% acrylic exterior paint with a UV-stable resin and a proper bonding primer is the standard. If the aluminum is dented or corroded at panel seams, repair must happen before paint, not after.
Wood trim, fascia, and soffit is where the painter earns the quote even on brick or aluminum homes — most pre-2000 GTA builds have wood trim, and the trim is where prep work decides whether the new paint job lasts 5 years or 5 months. Failing caulking, soft wood at corners, peeling paint from previous freeze-thaw — these are not extras, they are the prep that determines outcome. Quotes that do not itemize trim repair separately are either lumping it into the per-square-foot rate (acceptable if the contractor has walked the perimeter and seen the wood condition) or under-pricing the job (and will come back as a change-order three weeks in).
The prep that decides 5-year vs 18-month lifespan
Exterior paint failure is almost never the paint itself. It is the prep. The same gallon of high-end acrylic that lasts 8 years on properly prepped stucco will fail in 18 months over chalked, dirty, or improperly primed substrate. The honest prep checklist for a Toronto exterior repaint is:
  1. Pressure wash the entire painted surface to remove chalk, mildew, dust, and loose paint. Skipping this is the single most common reason cheap quotes fail fast. Power washing should happen at least 24 hours before paint goes on, ideally 48, so the substrate is fully dry.
  2. Scrape and sand any peeling, cracking, or alligatored paint down to sound substrate. On older Toronto homes this can mean significant work on south-facing walls and any wall over an asphalt driveway (heat reflection accelerates paint failure on those walls).
  3. Repair wood damage — soft trim, separated mitre joints, rot at fascia ends, missing caulk at corner joints. Re-caulking is part of this step, with paintable acrylic-latex caulk rated for exterior use.
  4. Spot-prime or full-prime as needed. Bare wood, bare metal, exposed substrate from scraping, or any surface where the existing paint is glossy or oil-based all need primer before the new acrylic. Spot priming is acceptable on a partially failed paint surface; full priming is required when going from oil-based to acrylic, when going over chalking that did not fully wash off, or when changing from a darker colour to a lighter one.
  5. Mask everything — windows, doors, light fixtures, decking, planters. The painter who skips masking saves 4 hours and creates 12 hours of touch-up work on the homeowner side.
A Toronto repaint quote that does not break out these five steps in writing is not a complete quote. The price difference between a contractor who does all five and one who does two of five is usually 20 to 35 percent — and the difference in how the paint looks five years later is night and day.
Booking window: when spring 2026 quotes get tight
Toronto exterior painting weather window opens roughly mid-April (consistent overnight lows above 5°C, daytime highs above 10°C) and runs through mid-October. The peak demand window is May through July, and the painters who book early are usually full by late June for July starts. The pricing implications:
  • April or first half of May booking: best window for a discounted quote. Several major GTA contractors are running spring promotions through mid-May 2026 — typically 5 to 10 percent off projects above $2,500.
  • Mid-May through July: full price. Painter availability tightens; expect 4 to 8 week lead times on starts.
  • August through mid-October: secondary discount window. Some painters cut rates 5 to 10 percent in late September and early October to fill the calendar before weather closes.
  • Late October through April: too cold for most acrylic exterior paint (most products require ambient temperatures above 10°C for at least 24 hours after application).
If the goal is a 2026 repaint at the best price, the call to make this week or next is the call that gets the discount. Calls placed in mid-June for a July start will not.
The reno fraud pattern that surfaces every spring in the GTA repeats almost exactly across painters, deck builders, and roofers. The painter-specific tells are:
  • No proof of WSIB and no certificate of liability insurance — non-negotiable. A Toronto painter who falls off a ladder while uninsured is your liability, not theirs.
  • Verbal-only quote, no written scope. The five prep steps must be on the page.
  • “Free upgrade to two coats” presented as an extra. Two coats is the minimum standard for an exterior repaint; one-coat exterior jobs fail by year two on south-facing walls.
  • Same-week start in May or June. Reputable Toronto painters are booked 4 to 8 weeks out in peak season. Same-week starts in May either mean the painter has cancellations from unhappy customers, or is desperately under-priced and will surface change-orders mid-job.
  • Cash-only with a discount for cash. The cash discount is an HST evasion signal and removes any consumer-protection recourse if the job fails.
  • Out-of-area phone number with no local address. The contractor who shows up in a rented van and disappears after Labour Day is the contractor who skipped the prep on a back wall you cannot see from the street.
Where the homeowner side actually moves the price
The cheapest way to get a $4,000 quote on a $7,000 home is to do the colour-and-decision work before the painter arrives. Painters quoting against indecision quote high to protect themselves from re-coats and change-orders. A homeowner who has already chosen a manufacturer-name colour, knows whether they want satin or low-sheen, and has a clear “yes paint” / “no paint” decision on every architectural element (front door, garage door, soffit, fascia, window trim, foundation parge) will get a tighter quote than the homeowner who says “what do you think looks good.”
For inspiration and recent Toronto-specific examples: a 1963 Toronto semi with brick-front and stucco sides went through this exact decision tree last summer, with the cost breakdown and what they wished they had done differently. A 1910s row house in Roncesvalles is going through the colour decision right now. Both threads are worth reading before the second painter quote comes in.
$RENO close
This forum runs a community token called $RENO that helpful contributors earn when they post project breakdowns, before-and-afters, contractor experiences, and renovation cost tracking. If you are posting a 2026 exterior repaint experience — your quotes, your contractor pick, your prep checklist, your before-and-after — that is exactly the content that earns. Welcome to $RENO — Quests, Rewards, Leaderboard. Top contributors at the homeowner-experience and trades intersection are tier-up candidates. Link a Solana wallet on signup to claim earnings when on-chain settlement opens.
From LF Builders
LF Builders handles exterior repaints as part of full-envelope renovation work across the GTA. If your spring inspection turns up rot at the fascia, failed caulking at window joints, or substrate damage that needs repair before painting, see lfbuilders.ca for a combined repair-and-paint quote. Samm Simon is running 251 km for cancer research — real spring 2026 exterior repaint breakdowns posted to this forum support the community and the cause.
