The reason kitchen appliances make some homes feel hotter during the day
Do you know that it’s not only the weather makes a house hot during the day, kitchen appliances also add a lot of heat inside the home.
The ovens, gas cookers, microwaves, kettles, and even fridges contribute to the heat in every home because they emit heat. When all of some appliances oare used at the same time, the kitchen becomes warmer very fast. That heat then spreads to other rooms nearby.
Some homes are hotter because the kitchen in them is small and has poor airflow. If windows stay closed or there is no fan, hot air remains trapped inside for a long time.
Fridges also add heat quietly. Many people do not know this because the inside is cold, but the back of the fridge releases warm air into the room all day and night.
Cooking in the afternoon can make the heat worse, especially when the weather is already hot outside.
Simple things can help reduce the heat. Opening windows, using fans, and giving appliances enough space around them
can improve airflow.
In many homes, kitchen appliances are one hidden reason the house feels hotter during the day.
Small kitchens especially feel it fast a fridge will works like a tiny heater behind the scenes all day
Watch: Kitchens renovation shorts
