If you’re about to start a renovation, stop — and read this first.
I’ve seen it a hundred times: a homeowner watches a few YouTube videos, gets inspired, and jumps straight into demolition before a single measurement or budget line is written down.
The mistake: Starting before you have a complete, detailed plan with contingencies.
The fix is simpler than you think:
Measure everything three times. Not twice — three times. Order materials only after you’ve verified every dimension against your actual space.
Add 20% to your budget before you look at materials. Renovations always uncover surprises: old wiring, hidden water damage, framing that’s not up to code. A buffer isn’t pessimism — it’s professionalism.
Write down the order of operations. What needs to happen first? Demo, then rough-in electrical and plumbing, then insulation, then drywall, then finishes. Skipping steps or doing them out of order costs you time and money.
Get at least three quotes for every trade. The cheapest isn’t always the best, but the most expensive isn’t either. You’re looking for someone who communicates clearly and shows up when they say they will.
What’s the biggest mistake you’ve made (or seen) in a renovation? Drop it in the comments — we all learn from each other’s hard lessons here.
BuildersLTD — verified pro since 2020
That mistake has its own shirt now — D.I.Y. Didn’t Inspect Yet, made by us.
