Proper ventilation in the home improves appliance performance and lifespan
Good ventilation in a home is something a lot people don’t pay attention to, but it plays a big role in how well appliances work and how long they last.
When appliances do not have enough space around them, heat builds up. The heat has nowhere to go, so it stays inside or around the appliances , and that makes the appliance work harder than normal.
For example, A frige needs space at the back and sides. If it is pushed too close to the wall, it won’t release heat properly, and this makes the compressor run more often and that affects its live span.
Televisions, air conditioners, and microwaves also need airflow around them. When they are placed in tight corners or closed spaces, they get hot quickly and that affects them.
Good ventilation also helps reduce the amount of power used. When appliances are not hot, they do not strain themselves so they use less electricity and do.the same job.
Dust is another problem in badly ventilated homes. Heat will make dust build up faster and block air flow, which adds more stress to the appliance.
Simple actions like leaving space at the back of appliances and not blocking ventilation sources can make appliances last long.
Good ventilation just makes everything work better less heat and moisture build-up, so appliances don’t struggle as much or wear out as fast over time.
Yes even for we humans, bad ventilation wears us out
Watch: Ventilation renovation shorts
