Preventing mould and damage by ventilating the bathroom
Do you know how a bathroom gets all steamy following a hot shower? That water does not simply evaporate. It goes into the walls, ceiling,and also the paint. If you leave it that way for too long, you will get mold. Molds are tiny black patches that smell terrible and cause sickness. They are very serious problems because they cause sickness in homeowners.
The solution to water going into walls us by drying the bathroom so the walls can become dry. The bathroom fan is important at this point. Every time you take a shower, run it and then leave it on for at least twenty minutes after you already left the bathroom. But a better fan if the one you have is not working properly or buy a new one of you don’t have at all.
Also, you can open the bathroom window. And Let the wind do its work. You can also use an old towel to wipe down your shower walls as well. All these won’t take you more than 10 seconds and will save you a lot of time later. If you do these small things every time, your bathroom will remain dry and spotless. No mold, no damage and no need for cost future repairs.
Bathrooms need proper airflow or moisture just builds up and leads to mould over time. The simplest fix is making sure steam can escape quickly using an extractor fan during and after a shower, or opening a window so the room can dry out properly instead of staying damp.
If it stays there too long, it can lead to mold, those dark patches that can damage surfaces and affect air quality in the bathroom
That’s very true. If moisture stays for too long, it can lead to mold growth, those dark patches that damage surfaces and even affect air quality, especially in bathrooms.
Proper ventilation would prevent mould and also wet walls that lead to cracks
This is actually something many people ignore until the damage becomes obvious bathroom moisture may look harmless at first but over time it really affects walls paint and even the smell of the whole space.
That’s a very important point. A lot of people think bathroom steam disappears on its own, but trapped moisture slowly damages paint, drywall, and ceilings over time. Simple habits like using the exhaust fan, opening a window, or wiping down wet surfaces can make a huge difference in preventing mold and expensive repairs later.
Watch: Bathrooms renovation shorts
