Painting with Confidence
Painting is one of the most common renovation tricks. In the past, I would be petrified when it comes to deciding on what colors I should use. However, here’s the tip – get yourself some color samples and see how the shades would look at different times of the day.
As far as painting techniques go, don’t just settle for a simple roller-on-flat. Try painting ombre walls or stripes using a laser guide . One of the best techniques I’ve learned is color blocking it makes my bedroom feel a little bit cozier and more sophisticated behind my bed.
The final piece of advice that I would give anyone who is planning to renovate his or her living space is be bold! Your perfect beige can turn into dirty bandages tomorrow. Just trust your instincts and enjoy the process.
Testing samples in different lighting and using bold techniques like color blocking helps create more personalized, visually dynamic spaces.
I learned the hard way that paint can look completely different once the sunlight changes testing samples first really saves regret later and yeah, bold colors usually end up looking better than safe boring ones.
