Ontario's Home Renovation Savings Program: which 2026 rebates are actually worth claiming?
Ontario’s Home Renovation Savings Program 2026: which rebates (heat pumps, insulation, windows, thermostats) are worth claiming and which to skip.
Ontario’s Home Renovation Savings Program stacks Enbridge + Save on Energy rebates from $75 up to $17,000+ across heat pumps, insulation, windows, and smart thermostats — confirmed running through November 2026. Been getting a lot of questions at the shop this month about it, and half the homeowners I talk to either do not know it exists or think it is only for heat pumps.
What is actually on the table
The program can stack rebates from about $75 (smart thermostat only) all the way up to $17,000+ if you are swapping out oil heat for a cold-climate heat pump and layering the federal Oil-to-Heat Pump Affordability grant on top. Most homeowners I have quoted fall in the $1,500 to $7,500 range. Key line items worth knowing:
  • Up to $5,000 for gas-heated homes, up to $10,000 for electrically heated homes on heating upgrades
  • Up to $7,700 on the bundled insulation stream (attic + walls + basement + air sealing)
  • Up to $1,000 on the attic-only stream with no energy audit required
  • $100 per rough opening for qualifying windows and doors
  • $100 for a smart thermostat, up to $200 for some appliances
The two paths to know: single-upgrade (one measure, no audit, faster cheque) vs. bundled (multiple measures, energy audit required, significantly higher rebate ceiling). If you are already planning a major renovation involving insulation + windows + HVAC changes, the bundled path is worth the audit cost.
Which upgrades have the best payback
Cold-climate heat pumps — highest upfront cost, highest rebate ceiling, and the most meaningful long-term energy saving for a gas-heated GTA home. If your furnace is aging and you are already thinking about replacement, the rebate stack right now is the best it has been in years.
Attic insulation (single-upgrade path) — one of the most practical upgrades we recommend. No audit required, direct cheque of up to $1,000, and most GTA homes built before 1990 are underinsulated in the attic. Payback on energy savings alone is typically 4–7 years.
Windows — the $100 per rough opening sounds modest, but on a full-house window replacement (12–16 windows), it adds up to $1,200–$1,600 back. More importantly, the upgrade itself saves on both heating and cooling costs.
Smart thermostats — simplest entry point. $100 back, immediate installation, and most HVAC systems installed in the last 15 years are compatible.
What to watch for
Not every contractor is registered to perform work under the program. Verify registration before signing. The application process requires keeping all receipts, invoices, and product specification sheets. For the bundled stream, energy audits must be performed by a Registered Energy Advisor before AND after the upgrades — the before-audit must happen before any work starts.
One more thing worth flagging while this thread is fresh: the pre-retrofit audit has a real bottleneck right now. The registered Energy Advisor pool in the GTA is slammed. I booked a client’s pre-audit three weeks ago in Scarborough and the earliest slot was mid-May. If you’re planning a kitchen gut reno or basement finish for summer, get the audit booked before you even swing a hammer — otherwise your “bundled path” turns into a “single-upgrade path” because demo started before the advisor could walk the house.
A couple of real-world rebate examples from the last 60 days so people can calibrate:
  • East York semi: attic-only stream, no audit. $1,000 back, cheque landed in 5 weeks. Clean and simple.
  • Etobicoke bungalow: bundled audit, attic + rim joist + basement walls + air sealing + cold-climate heat pump swap. Stacked rebates came in at $12,400. Federal Oil-to-Heat Pump grant was not eligible (was already on gas), so federal stack stayed off. Post-audit took 9 weeks to schedule after project finish — plan for the cash flow gap.
  • North York Scarb border: homeowner tried to claim $100 smart thermostat rebate without registering through the program portal first. Denied. The paperwork order matters — enrol first, install after.
On the electrical code angle: if you’re doing a panel upgrade in 2026, the AFCI expansion is where most of the surprise cost shows up. It’s not huge per circuit, but on a full panel swap it adds up. Worth getting the ESA permit scoped up front so you’re not finding out mid-reno.
If anyone reading this is mid-quote and wondering whether your contractor is actually factoring in the rebate scope properly, post the quote details (redacted) and I’ll walk through whether it’s structured to capture the bundled path or if you’re about to leave money on the table.
Getting a lot of DMs asking the same order-of-operations question, so parking the short answer here for anyone landing on this thread later.
The sequence that actually keeps your rebates intact:
  1. Book the pre-retrofit audit before you touch anything. The moment you demo a wall, pull insulation, or swap a furnace, the bundled-path rebates are off the table. The advisor needs to see the “before” state.
  2. Run your contractor quotes past the audit report, not the other way around. Most homeowners do this backwards - they get a quote for windows or a heat pump first, then scramble to fit it into the rebate categories. The audit report tells you which measures qualify at what rate. Quote second.
  3. Keep the paperwork separate by measure. Each rebate category (heat pump, insulation, windows, thermostat) wants its own invoice line, model/serial numbers, and installer info. Don’t let your GC lump it all under “Renovation - $42,000.” I’ve seen clean rebate files get kicked back for that.
  4. Book the post-retrofit audit before the final payment. Same advisor, ideally. You need the post-audit on file to unlock the bundled bonus.
The three disqualifiers I see most often:
  • Homeowner replaces equipment “on emergency” (busted furnace in February) and skips the pre-audit. Understandable, but that measure won’t stack.
  • DIY install on anything mechanical. Heat pumps and hot water heat pumps need a licensed HVAC installer on the paperwork, no exceptions.
  • Buying the equipment before the audit is logged. Even if install happens later, the purchase date matters on some categories.
If anyone here has actually closed out a full bundled claim in 2026, drop the rough timeline in a reply - homeowners reading this are starved for real-world schedules.
Watch: Heating & Cooling renovation shorts
