Ontario Window and Door Replacement Complete Buyer Guide 2026
Ontario Window and Door Replacement Buyer Guide 2026
Windows and doors are among the most impactful energy and comfort upgrades for GTA homes. Here is everything you need to know before buying in 2026.
When to Replace
  • Failed sealed unit (condensation between panes): Replace now — insulating value gone
  • Single-pane glass (pre-1980 homes): Replace — R-1 vs. R-5 for triple-pane
  • Rotting or damaged frames: Replace before wall damage spreads
  • Air infiltration around frames: Incense test — movement = leakage
  • Windows over 25 years old: Performance has degraded significantly
Energy Star Requirements (Ontario, Climate Zone 6)
  • Maximum U-factor: 1.22 W/m2K
  • Minimum ER: 34 for casement/fixed, 29 for sliding
  • Triple-pane achieves ER 40-55 — significantly above minimum
Payback on energy savings alone: 20-30 years. Real ROI is comfort, resale value, and draft elimination.
Frame Materials
Material Performance Maintenance Cost
Vinyl (uPVC) Good Very low Low-medium
Fibreglass Excellent Very low Medium-high
Aluminum (thermal break) Fair-good Low Medium
Wood/aluminum clad Excellent Low exterior High
Insert vs. Full Frame Replacement
Insert: New window into existing frame. Lower cost. Only if frame is in good condition.
Full frame: Remove to wall studs. Best performance. Required for old or deteriorated frames.
Cost Guide (GTA 2026)
Type Cost per Window (installed)
Vinyl double-pane insert $400-700
Vinyl triple-pane insert $550-900
Fibreglass full-frame $900-1,600
Fibreglass triple-pane, full-frame $1,200-2,500
Patio sliding door $1,500-3,500
Find GTA window replacement contractors on home.renovation.reviews.
LF Builders has replaced windows and doors across the GTA for over 50 years. lfbuilders.ca
