Ontario Septic System Guide 2026 - Types, Inspection Requirements and Replacement Costs
Septic systems serve approximately 1 million Ontario properties outside municipal sewer service areas. This guide covers system types, Ontario inspection requirements, maintenance schedules, and 2026 replacement cost ranges for rural and cottage properties.
Ontario Septic System Types
Class 4 (conventional septic bed): Most common. Septic tank (primary treatment) + leaching bed (secondary treatment in soil). Requires minimum lot size and setbacks from wells, water bodies, and property lines per OBC.
Class 5 (filter beds): Used where soil drainage is poor or water table is high. Raised bed system requiring more land area.
Class 6 (aerobic treatment unit/ATU): Mechanically aerates sewage for higher treatment level. Required near sensitive water bodies. Annual maintenance contracts required.
Class 9 (holding tank): No treatment β€” full pump-out required periodically. Used only where no other system is feasible. Very high operating cost.
Mandatory Real Estate Inspection
Ontario requires a Certificate of Approval or inspection record for septic systems in real estate transactions. Most lenders require a septic inspection as a mortgage condition. Budget $300-$600 for qualified inspection.
Maintenance Schedule
Pump septic tank every 3-5 years. Annual inspection of distribution box and leaching bed. Never drive over leaching bed. Do not flush wipes, medications, or chemicals.
Replacement Costs (Ontario 2026)
  • Class 4 conventional (3-bedroom): $20,000-$40,000
  • Class 5 raised bed: $30,000-$55,000
  • Class 6 ATU: $25,000-$45,000 plus $500-$1,200/year maintenance
Full guide: https://telegra.ph/Ontario-Septic-System-Guide-2026---Inspection-Maintenance-and-Replacement-Costs-04-26
Watch: Plumbing renovation shorts
