Ontario secondary suite rules in 2026: what's actually changed for Toronto homeowners
Ontario’s 2025-2026 secondary suite reforms opened Toronto ARUs, garden suites, and laneway builds - but fire, HVAC, and parking still kill most permits.
There’s been enough quiet noise from homeowners about basement apartments, garden suites, and laneway builds this spring that it’s worth putting the 2026 state of play in one place. A lot of the older threads on this forum were written against pre-2025 rules, and the ground has shifted enough in the last year that some of that advice is out of date.
Here’s the short version of what’s actually in force in Toronto right now, April 2026.
Ontario Regulation 462/24 is the backbone
O. Reg. 462/24 came into force November 20, 2024, and it’s the provincial lever that pushed municipalities — Toronto included — to simplify Additional Residential Unit (ARU) rules. Two of the biggest wins for homeowners:
  • The old angular-plane requirement is gone for garden and laneway suites. That alone has unblocked a lot of tight lots that used to fail a setback math problem nobody could solve without shrinking the whole build.
  • Up to 45% of your lot can now be covered by buildings including ADUs, up from the older tighter coverage caps.
  • Minimum 4 m between the primary dwelling and the garden/laneway suite, with some height restrictions attached.
The regulation caps out at three residential units per property (primary home + second unit inside + one garden/laneway). It doesn’t apply if the main building is already a triplex or bigger — that’s a different path.
Toronto By-law 849-2025 layered on top
Adopted by Council on July 24, 2025, this one amends the city-wide Zoning By-law 569-2013 to bring Toronto’s garden suite rules in line with the provincial regulation. If you were quoted numbers on garden suites in 2023 or 2024, have your designer re-check — the permissions are wider now.
What still trips homeowners up
The permit and code side hasn’t gotten looser, and this is where almost every stalled project on our books this spring has gotten stuck:
  • Fire separation. 45-minute fire-rated assembly between the two dwelling units is non-negotiable. Ceilings, party walls, any shared mechanical penetrations.
  • Egress. Proper window or door that meets the code-specified clear opening. A 24x24 basement window you could wriggle out of in 1998 does not meet current rules.
  • Ceiling height. Minimum 6’5" under beams/ducts, 7’ for general habitable area. This is the one that kills the most old bungalow basement conversions.
  • Interconnected smoke and CO alarms across both units, hardwired.
  • Separate entry — strongly preferred, required in some zones.
  • Parking — one space per unit remains the working baseline.
The cost side — permits went up in January
City of Toronto interior alteration permit fees moved to $11.09 per square metre effective January 1, 2026, with a minimum of $206.53 and a 4.82% year-over-year increase. For a finished 1,000 sq ft basement that’s roughly $1,000-$1,500 in permit fees alone, before drawings. Budget another $2,000-$5,000 for an architect or BCIN designer — and for secondary suites, you want drawings, not just a sketch.
Processing time on a straightforward interior scope is running 2-4 weeks. Secondary suites with new plumbing/electrical/egress are sitting longer, and Toronto’s permit desk has been a known bottleneck — there’s a good existing thread on that here.
Where this leaves the average homeowner
If you looked at a secondary suite in 2022 or 2023 and walked away because the math didn’t work, it’s worth running it again. A lot of the design constraints that killed projects back then (angular plane, tighter lot coverage, stricter setbacks on laneway builds) have been softened. What hasn’t softened is life safety — and that’s the right place for the rules to hold firm.
A few questions worth throwing out to the forum:
  • Anyone gone through a garden suite permit under the new 849-2025 rules yet? How did the review go?
  • Homeowners who abandoned a basement suite idea pre-2025 — has your designer re-run the numbers this year?
  • Are we seeing any shift in rental demand in Toronto that’s changing the ROI math on secondary suites vs. just finishing the basement for yourself?
Happy to dig into specifics on any of this. If you’re in the GTA and not sure whether your property even qualifies, the first $0 step is pulling your property’s zoning from the city’s AIM tool before you pay anyone for drawings.
A lot of what I’ve learned on this stuff came from 50+ years of my crew pulling non-compliant suites back into code after the fact — which is almost always 3-5x the cost of doing it right the first time. The rules being simpler now is a real win; the code still matters.
Piggybacking on the ROI question since it’s the one I get asked in the driveway, not in the office.
The financing side has moved in parallel with the zoning side. Effective January 15, 2025, CMHC-insured mortgage refinancing for homeowners adding a secondary suite now goes up to 90% of post-renovation property value, on homes up to $2M, amortized over 30 years. That’s a meaningful shift: the lender underwrites against what the house will be worth with the suite in place, not what it’s worth today, which is the piece that historically blocked basement-apartment financing.
Also worth checking: the federal Multigenerational Home Renovation Tax Credit (15% back on up to $50K of eligible costs if the suite is for a senior or adult with a disability joining your household). Not every conversion qualifies, but when it does it’s real money off a real tax bill.
One red flag in post-849-2025 quotes: contractors occasionally price garden suites against pre-2025 setback math and hope the cheaper design clears review. Ask your designer to cite O. Reg. 462/24 and Toronto By-law 849-2025 by section number in the drawings, not just “current code”. Saves a round of revisions at the permit desk.
Hey Daniel, please can you respond to my messages on telegram?
I sent you a message and it’s very important.
One piece that doesn’t come up in most of the policy write-ups but eats budgets faster than anything else: the fire-separation and egress pieces on basement conversions. None of the 2024/25 changes touched OBC Part 9.10 or 9.9, so if you’re converting an existing basement into a second suite, you’re still on the hook for:
  • A full 45-minute fire separation between units, which in practice means two layers of 5/8" Type X drywall on the ceiling plus sealed penetrations. The existing ceiling almost always has to come down for this.
  • A compliant egress from the suite: either a proper window well (with the rough opening sized to OBC 9.9.10) or a walk-out.
  • Interconnected, hardwired smoke and CO alarms on both sides of the separation.
The one that catches people: ESA almost always wants a subpanel or a full panel upgrade once you’re running a second kitchen and laundry. If the house is still on a 100A panel from the '70s, budget $3–5K before framing even starts.
None of this kills a project — we’ve done plenty on Toronto 30-foot lots — but the new zoning wins only show up on the balance sheet if the building-code costs are priced in from day one. Happy to break any of it down if someone’s running numbers on a specific house.
