Ontario Renovation Checklist 2026 - Complete Pre-Project Guide for GTA Homeowners
Starting a renovation in Ontario without a proper pre-project checklist is one of the most common ways GTA homeowners end up over budget and over schedule. This complete checklist covers every step before you break ground.
Phase 1: Project Definition
  • [ ] Define scope in writing (what is included AND excluded)
  • [ ] Set realistic budget with 15-20% contingency
  • [ ] Confirm financing (HELOC, construction loan, or cash)
  • [ ] Determine occupancy during construction
  • [ ] Set target completion date with buffer
Phase 2: Permits and Approvals
  • [ ] Determine permit requirements (building, electrical, plumbing, heritage)
  • [ ] Check zoning bylaws for setbacks, height limits, lot coverage
  • [ ] Apply for permits BEFORE hiring contractor (establishes timeline)
  • [ ] For Toronto: check if property in heritage conservation district
  • [ ] Confirm condo/HOA approval if applicable
Phase 3: Contractor Selection
  • [ ] Get minimum 3 written quotes on identical scope
  • [ ] Verify WSIB clearance certificate (mandatory in Ontario)
  • [ ] Confirm $2M liability insurance minimum
  • [ ] Check HCRA registration for new homes / Tarion for new builds
  • [ ] Review HomeStars or Google reviews
  • [ ] Check BBB and Contractor Check ratings
  • [ ] Verify HST registration number
Phase 4: Contract Review
  • [ ] Fixed price vs. cost-plus clearly stated
  • [ ] Payment schedule tied to milestones (never >10% deposit)
  • [ ] Lien holdback clause (10% per Ontario Construction Act)
  • [ ] Change order process defined in writing
  • [ ] Material allowances clearly specified
  • [ ] Start and completion dates with penalty clause
Phase 5: Pre-Construction
  • [ ] Protect floors, furniture, HVAC intakes from dust
  • [ ] Confirm utility locates (Ontario One Call - 1-800-400-2255)
  • [ ] Establish site access and working hours with neighbours
  • [ ] Arrange temporary accommodation if needed
  • [ ] Document existing conditions with photos/video
Full detailed guide for each phase: https://telegra.ph/Ontario-Renovation-Checklist-2026-Complete-Pre-Project-Checklist-for-GTA-Homeowners-04-26
This is a strong checklist. A few additions for anyone starting a project in spring 2026, because two things have shifted in the last 90 days that change the math on Phase 1 and Phase 2.
On budget contingency. The 15 to 20% rule was correct for 2024. For pre-1960 GTA homes, push that to 20 to 25% in 2026. Tariff-driven price movement on lumber, steel, and a chunk of finish goods is now in the 10 to 60% range depending on category, with lumber tracking 25% higher by mid-year. If your scope includes any framing, decking, or structural rework, a quote that is more than 60 days old is almost certainly stale.
On permits. Two things every applicant in Ontario should know going into a 2026 application. First, as of February 16, 2026, applications must use the updated Application for a Permit to Construct or Demolish form. Older versions get returned. Second, Toronto residential alteration fees are now calculated at roughly $8 per square metre with a $290 minimum, so plan that line item against your scope drawing area, not your usable square footage. The two numbers are not the same and homeowners get caught.
Last note on Phase 3. WSIB clearance and a current liability cert in your name are mandatory minimums, not nice-to-haves. Anyone who pushes back on producing them is filtering themselves out of the shortlist for you.
