Ontario Mould in Homes: Causes, When to DIY vs Call a Pro & Prevention Strategies
Mould is among the most commonly mishandled home issues in Ontario. Here is a clear, evidence-based guide to causes, remediation, and prevention.
Why Ontario Homes Are Mould-Prone
Ontario’s humid summers and cold winters create ideal mould conditions. Summer humidity drives moisture into cooler basement spaces. Condensation forms on cold window frames and walls in winter. Inadequate bathroom ventilation traps moisture. Common problem areas: basement walls, bathroom ceilings, window frames, attics, and behind kitchen sinks.
Health Canada Guidelines on Remediation
DIY remediation appropriate for areas under 1 sq m (10 sq ft): clean with detergent, dry completely, address moisture source. Areas over 1 sq m: hire a certified mould remediation professional. Attic or HVAC mould of any size: professional remediation.
Professional Remediation Costs Ontario 2026
Typical basement mould remediation: $1,500-$8,000 depending on extent. Includes containment, HEPA air scrubbing, removal of contaminated materials, antimicrobial treatment, and clearance testing.
Prevention
Fix water intrusion sources immediately — no mould remedy lasts with an ongoing moisture source. Maintain indoor relative humidity below 50% in summer (dehumidifier) and 30% in winter. Ensure bathroom exhaust fans vent outside (not to attic). Provide adequate attic ventilation.
Attic Mould — A Special Case
Attic mould in Ontario typically results from bathroom or kitchen exhaust fans venting into the attic instead of outside, or from inadequate attic ventilation causing condensation. Fix the ventilation source, then remediate.
Discuss mould issues and find Ontario remediation contractors at home.renovation.reviews.
