Ontario Hot Water: Tank vs Tankless vs Heat Pump Water Heater — Full Comparison 2026
Hot water system selection matters more than most Ontario homeowners realise. Here is a complete 2026 comparison.
Traditional Storage Tank
Most common in Ontario. 40-60 gallon gas or electric. Gas EF 0.6-0.7. Lower install cost ($800-$1,400). Simple maintenance. Standby heat loss is the main inefficiency.
Tankless (On-Demand)
Heats only when needed. Gas EF 0.8-0.98. Install cost $2,000-$4,000. Requires 3/4 inch gas line typically. Virtually unlimited hot water — but flow rate limited. Size carefully for simultaneous demand.
Heat Pump Water Heater (Electric)
Extracts heat from ambient air. EF 2.0-3.5 — dramatically more efficient than resistance electric. Requires ambient air source in basement or utility room. Canada Greener Homes Grant rebates available. Cost: $1,800-$3,500 installed.
Rental vs Purchase
Many Ontario homes rent from Reliance, EnerCare, or Direct Energy. Ownership cheaper over 7+ years. When buying a home, check for rental agreements on title — some carry buyout penalties.
When to Replace
Lifespan: 8-12 years. Signs: rust in hot water, rumbling (sediment), visible corrosion, pilot issues, age over 12 years.
Compare hot water options and get Ontario quotes at home.renovation.reviews.
