Ontario Home Inspection: What Gets Checked, Common Findings & How to Use Your Report
A home inspection is one of the most valuable tools available to Ontario buyers and homeowners. Here is a complete guide to getting the most out of one.
What a Standard Inspection Covers
Roof condition, flashings, and penetrations. Attic insulation, ventilation, and air bypasses. Exterior cladding, grading, and drainage. Foundation and basement: cracks, moisture, and structure. Electrical: panel, service size, GFCI protection. Plumbing: supply, drain, water heater. HVAC: furnace, AC, ventilation. Interior: drywall, windows, doors, floors.
What Inspections Do NOT Cover
Behind walls and under floors. Environmental hazards (mould, asbestos, radon — require separate specialist testing). Pools and hot tubs (often separate add-on). WETT inspection for wood-burning appliances (separate certification required).
Most Common Ontario Issues Found
Aging roofs (granule loss, curled shingles, missing flashings). Aluminum wiring (1965-1980 era — requires ESA evaluation). Knob-and-tube (pre-1940s). Undersized 100A panels. Basement moisture. Foundation cracks. Missing GFCI in wet areas. Attic air bypasses causing ice dams.
Costs Ontario 2026
Standard inspection: $400-$600. Larger homes: $500-$800. Add-ons: radon $150-$250, mould $300-$600, asbestos $200-$400, sewer scope $200-$400.
Using the Report
Prioritise life safety items for immediate action. Use specialist follow-ups for uncertain findings. Cosmetic items are normal wear — don’t over-negotiate minor issues.
Discuss home inspection findings and renovation priorities at home.renovation.reviews.
