Ontario Home Inspection 2026: What's Covered, What's Not and When to Get Specialty Inspections
Ontario home inspectors have been regulated since April 2023 under the Home Inspection Act. Understanding what you’re actually getting helps you identify gaps.
What a standard inspection covers (visual assessment only):
  • Roof covering, attic (if accessible)
  • Foundation and basement
  • Electrical panel and visible wiring
  • Plumbing fixtures and visible lines
  • HVAC equipment (operated and observed)
  • Windows, doors, cladding, grading
What it does NOT cover:
  • Anything behind drywall or under floors
  • Environmental hazards (asbestos, lead, radon, mould – unless visually obvious)
  • Wood-burning fireplaces (requires separate WETT inspection)
  • Swimming pool equipment
  • Septic systems or underground oil tanks
  • Engineering assessment of structure
Specialty inspections worth ordering separately:
| Pre-1990 home | Asbestos air quality test | $300-$600 |
| Suspected foundation movement | Structural engineer | $600-$1,500 |
| Wood-burning fireplace | WETT inspection | $200-$400 |
| All homes | Radon test | $30-$80 DIY |
| Rural property | Well water quality + septic pump-out | Varies |
Note: if reviewing a seller’s pre-listing inspection, commission your own inspection regardless – the inspector’s obligation is to the party who engaged them.
Ontario renovation and inspection questions at home.renovation.reviews
