Ontario Exterior Lighting Guide 2026 - Security, Landscape and Electrical Code
Exterior lighting upgrades are one of the best ROI renovations for Ontario homeowners in 2026. Combining security, curb appeal and energy efficiency, a well-designed exterior lighting system adds measurable value.
Types of Exterior Lighting
Security and Entryway Lighting
  • Motion-activated LED floods: $80-$250 per fixture installed
  • Video doorbell with integrated lighting (Ring, Nest): $200-$500 installed
  • Soffit-mounted LED downlights: $150-$350 per fixture
Landscape and Pathway Lighting
  • Low-voltage 12V landscape system: $1,500-$5,000 for typical GTA property
  • In-ground uplights for trees: $200-$400 each installed
  • Step and riser lights: $150-$300 per location
Smart Exterior Lighting
  • Lutron Caseta or similar smart switches: $80-$150/switch
  • Whole-home smart lighting integration: $2,500-$8,000
Ontario Electrical Code Requirements
All 120V exterior outlets and lighting circuits require GFCI protection per OEC Section 26-700. Exterior wiring must be in approved weatherproof conduit or use wet-location rated cable.
Landscape low-voltage systems below 25V are not regulated by ESA, but 120V transformer connections require licensed electrical contractor.
ESA Permit Requirements
Any new 120V exterior circuit requires an Electrical Safety Authority (ESA) permit. Inspections typically add 2-3 weeks to project timeline. Budget $150-$300 for ESA permit fees.
Complete code guide and fixture recommendations: Ontario Exterior Lighting Guide 2026: Security, Landscape and Code Requirements – Telegraph
Watch: Electrical renovation shorts
