Ontario Exterior Door Replacement Guide 2026: Energy, Security, and Style
Exterior Door Replacement for Ontario Homes 2026
Replacing an exterior door improves curb appeal, energy efficiency, and security in one project. This guide covers door materials, Energy Star requirements, frame options, and GTA costs.
Door Material Comparison
Material Ontario Performance Maintenance Cost (installed)
Fiberglass Excellent (R-5 to R-8) Very low $2,500-5,000
Steel Very good (R-5 to R-7) Low $800-2,500
Wood Fair (R-2 to R-3) High $2,000-6,000+
Wood/fiberglass clad Excellent Low $3,500-8,000+
Recommendation for GTA: Fiberglass is the best all-round choice — outperforms steel in thermal performance and outperforms wood in maintenance demands.
Energy Star Requirements (Climate Zone 6)
  • Maximum U-factor: 1.22 W/m2K (R-4.6 effective)
  • Minimum ER (Energy Rating): 20 for hinged doors
  • Triple-seal weatherstripping for minimum air leakage
  • Look for Energy Star Canada certification label
Frame Replacement vs. Insert Only
Insert only: Lower cost, preserves existing frame. Only suitable if frame is square, rot-free, and properly insulated.
Full frame replacement: Required when frame is rotted, out of square, or improperly insulated. Add $500-1,500 labour. Strongly recommended for doors over 20 years old in Ontario.
Security Upgrades
  • Grade 1 deadbolt (ANSI/BHMA A156.30)
  • 3-inch screws in strike plate (into studs, not just door jamb)
  • Door reinforcement kit at lock points
  • Multi-point locking system (3 or 5-point) for maximum security
Cost Guide
Scope Cost
Steel door (slab only) $800-1,500
Fiberglass + full frame replacement $2,500-5,000
Premium entry + sidelights + transom $5,000-12,000+
Threshold + weatherstripping only $300-600
Find Ontario door installers and renovation contractors on home.renovation.reviews.
LF Builders has replaced thousands of exterior doors across the GTA since 1974. lfbuilders.ca
