Ontario Electrical Panel Upgrade 2026: 100A vs 200A, EV Chargers and GTA Costs
Panel upgrades are one of the most common renovation-triggered electrical projects in Ontario. Here’s a complete breakdown for 2026.
Signs you need an upgrade:
  • Fuse panel (glass fuses) – must be replaced
  • Fewer than 20 circuits in a 3+ bedroom home
  • Planning EV charger (Level 2 requires 40-60A dedicated circuit)
  • Installing heat pump, hot tub, or basement apartment
  • Breakers tripping regularly
Service size guide:
  • 100A: Marginal for modern loads. Struggles with EV + heat pump + modern kitchen simultaneously.
  • 200A: Standard for all new construction and most upgrades. Handles typical modern loads comfortably.
  • 400A: Large homes with multiple EVs, radiant heating, or detached garage subpanels.
GTA cost ranges (2026):
  • 100A to 200A upgrade: $2,500-$4,500
  • 200A service + new panel: $3,000-$5,500
  • 400A service upgrade: $6,000-$10,000
  • Subpanel (garage/basement apt): $1,200-$2,500
  • Level 2 EV charger circuit: $800-$1,800
ESA process: All electrical work requires ESA permit + inspection. ESA certificate is checked by insurers and in real estate transactions.
Licensed electrician referrals at home.renovation.reviews
Watch: Electrical renovation shorts
