Ontario Crawl Space Encapsulation 2026: Why Vented Crawl Spaces Fail and Full Encapsulation Costs
Vented crawl spaces are a known building science failure in Ontario’s climate. Encapsulation is the proven solution. Here’s the 2026 guide.
Why vented crawl spaces fail in Ontario:
Warm, humid summer air enters the vented crawl space and condenses on the cooler floor joists and subfloor – depositing moisture exactly where you don’t want it. Research established 20+ years ago that sealed, conditioned crawl spaces outperform vented ones in humid continental climates.
Full encapsulation process:
  1. Seal all foundation vents permanently
  2. Install heavy-duty poly liner (minimum 10 mil, preferably 20 mil) on ground and up walls
  3. Tape all seams and wall connections
  4. Rigid insulation on interior foundation walls
  5. Dehumidifier or conditioned air connection
  6. Seal access hatch to same standard
Critical: Remediate any existing mould before installing liner – encapsulation seals problems inside the structure. Surface mould on wood: treat with borate solution (Tim-bor, Boracare). Structurally compromised joists: sister or replace first.
GTA cost ranges (2026):
Scope Cost
Basic encapsulation, liner + vent sealing (600-800 sq ft) $3,000-$6,000
Full encapsulation with wall insulation and dehumidifier $8,000-$16,000
Mould remediation (if needed) +$1,500-$5,000
Energy savings: typically $400-$800/year in reduced heating costs.
Crawl space and moisture questions at home.renovation.reviews
