Ontario Basement Waterproofing Methods Compared 2026: Interior, Exterior, and Injection
Basement water intrusion is one of the most common and costly problems for GTA homeowners. Here is a clear breakdown of the three main approaches and when each is appropriate.
How Water Enters GTA Basements
  • Hydrostatic pressure through porous concrete or block
  • Lateral soil pressure through cracks
  • Window wells with inadequate drainage
  • Cove joint (wall meets floor slab)
  • Surface grading sloped toward house
  • Failed weeping tile (original clay or perforated pipe)
Interior Drainage System
Best for: Hydrostatic pressure, cove joint seepage, ongoing wall seepage.
How it works: Perimeter drainage channel cut into floor at foundation wall base, dimple mat on walls, sump pump with battery backup, discharge to daylight or storm sewer.
Does not address: Exterior drainage issues, structural wall damage, window well flooding.
Cost: $8,000-18,000 for average GTA home.
Exterior Waterproofing
Best for: Comprehensive solution, new weeping tile, structural wall concerns.
How it works: Excavate to footing depth, apply waterproofing membrane, install dimple mat drainage board, install new weeping tile, backfill with granular.
Most disruptive. Usually requires landscape restoration.
Cost: $25,000-60,000+ for full perimeter.
Crack Injection
Best for: Isolated cracks in poured concrete walls.
  • Polyurethane foam: Active leaks, flexible, cures in moisture
  • Epoxy: Structural repair, rigid, non-active cracks
Not appropriate for: block foundations, rubble stone, cove joint leakage.
Cost: $400-1,200 per crack.
Sump Pump — Non-Negotiable
Regardless of waterproofing method, every GTA basement needs: 1/2 HP pump, airtight lid, battery backup, check valve. Test annually.
Find Ontario waterproofing specialists on home.renovation.reviews.
LF Builders specializes in basement waterproofing across the GTA. lfbuilders.ca
