I recently renovated my garage following modern garage trends. Before the renovation, it was dark, messy, and used only for storage, with no proper organization. I decided to change it into a more functional and modern space. I installed wall-mounted shelves and vertical storage systems to free up floor space. Bright LED lighting was added to improve visibility, and I created a small workbench area for DIY tasks. I also repainted the walls with neutral colours and upgraded the flooring for a cleaner look. After the renovation, my garage became organized, brighter, and more useful as a multi-purpose space.
Thank you for sharing your experience I will make sure I apply it on my renovation o see a good result
I didnβt know garages can have led lights, wow.
Garage renovation always looks simple at first, but once you start you realize itβs usually storage, flooring, and hidden fixes that take most of the time and effort.
Garages really change once you add proper lighting and organization, it makes a huge difference
Watch: Garages renovation shorts
Epoxy-coat your garage floor
Oddly satisfying garage storage trick! π€―
Did I just ruin my house? #garageorganization #diyideas #organization
Brilliant Garage Storage Solution
Quick garage storage hack. #diy #construction #tools #storage #garage
The ULTIMATE Garage HACK - Ratchet strap Storage #short
