Interlock driveways and patios in Ontario: why they fail and what a good quote actually includes (2026)
If you’ve spent time on renovation forums or GTA Facebook groups, you’ve seen the photos. Wavy interlock patios that looked perfect in the install photo and turned into a mess by April. Driveway stones shifted into a dozen different heights. Joints packed with weeds two years in.
It’s almost never the stone itself. It’s the base.
Why Ontario interlock fails
Ontario’s freeze-thaw cycle is brutal on anything that isn’t properly grounded. The ground heaves during spring thaw, and anything sitting on an inadequate base moves with it. A properly installed interlock driveway in the GTA needs a minimum 12 inches of compacted granular material below the bedding layer. Not 6. Not 8. Cutting from 12 to 6 saves a contractor 20 to 30 percent on time and material. For the homeowner, it means the job fails inside five years instead of lasting 30 to 50.
Polymeric sand: where cheap jobs fall apart
Polymeric sand is what holds the stones together at the joints. It activates with water, sets into a semi-rigid bond, and resists weeds and insects when it works correctly.
It doesn’t work when the stones were never compacted with a plate vibrator after the sand was swept in. The sand sits loose, doesn’t bond, and washes out in the first heavy rain. It also fails when the joints are overfilled — excess sand sitting on the stone surface stains it and prevents the material below from curing.
Ask your contractor what plate vibrator they’re using and whether it has a rubber pad. Without one, the plate can crack or chip the stone surface. A contractor who has done this before answers that question without hesitating.
Edge restraints: the quiet cause of creep
The stones are held in place by restraints at the edges. Without them properly spiked — at the right interval, driven into the base — the field migrates outward. You see it as gaps opening at the perimeter first, then the pattern buckling in the center.
Plastic edge restraints are standard. The difference is in how they’re installed. Low-end jobs space the spikes too far apart or skip them near curves. Ask what restraint product they spec and what spike interval they use on straight runs versus curves.
What a solid quote should include
A detailed interlock quote specifies the base depth in writing: not “proper base included” but the actual depth, the granular type (Granular A or B depending on the application), and the compaction standard. Polymeric sand should be standard, not listed as an upgrade. And the quote should say who is pulling any required permits. Driveway work touching the road allowance in many GTA municipalities requires one. If that gets skipped, the problem lands on you at sale or complaint.
Three questions before you sign
What is the base spec? Get the depth, the granular material type, and whether a plate compaction pass is included after the bedding layer.
Are you ICPI certified? The Interlocking Concrete Pavement Institute trains and tests installers on base preparation, drainage, and compaction. It’s not a guarantee, but it filters a lot of low-quality operators out of consideration.
What is your warranty, and what voids it? A contractor who is confident in their base work gives you a multi-year warranty on the installation. One who hedges on this question is telling you something.
We’ve built interlock pathways, driveways, and flagstone patios across the GTA for over 50 years. Most of the callbacks we’ve seen came from jobs where these questions weren’t asked before the deposit changed hands.
Questions on a quote you’re looking at, or an interlock situation you’ve dealt with? Post below. Top contributors on this forum earn $RENO — our Solana community token — for the help they share. The welcome topic has the full breakdown: Welcome to $RENO — Quests, Rewards, Leaderboard
I thinks It’s not properly grounded in Ontario the way of interlock driveways in Ontario isn’t properly done
Most failed interlock projects don’t fail because of the pavers themselves they fail because shortcuts were taken underneath. In Ontario especially, proper base depth, compaction, drainage, and edge restraints are what determine whether a driveway lasts five years or fifty.
Most interlock failures don’t start at the surface they start underneath. A beautiful driveway or patio can look perfect at first, but without proper excavation, compaction, drainage, and edge restraint installation, Ontario winters will expose every shortcut very quickly.
Solid breakdown of interlock failures. Base depth, compaction, and proper edge restraint matter far more than the stones themselves.
Thanks for this information, it opened my eyes to somethings I didn’t realise before.
The warranty part is important, anyone who can’t give you a warranty surely isn’t confident about what he’s done
Polymeric sand is another weak point when done wrong. If it’s not compacted properly, it won’t bond and can wash out quickly, leading to weeds and loose joints.
I think Ontario engineers are not really good in terms of interlock driveway but I think they are trying to improve already
Watch: Doors renovation shorts
