Concrete vs. interlock vs. asphalt driveways in Ontario 2026: how contractors make the call, and what changes when frost and drainage are the real constraints
Every spring in the GTA, we get calls from homeowners who chose the wrong surface. Not a bad contractor — wrong surface for the lot. Nobody told them upfront that the decision really comes down to three things that don’t appear in any quote: frost conditions, drainage obligations, and what they plan to do with the property.
The frost-depth issue applies to all three, not just interlock
Ontario’s freeze-thaw cycle does a number on driveways regardless of material. Most homeowners hear “8 to 10 inches of compacted granular base” and assume that’s a fixed standard. It’s not — it’s a minimum for typical soil. Clay-heavy lots (common in Etobicoke, Mississauga, north Brampton) need deeper excavation or a geotextile barrier layer to prevent differential heaving.
This matters for asphalt and concrete too. An asphalt driveway laid over 4 inches of base on a clay lot will develop ruts and alligator cracking before year five. A concrete slab without adequate base prep will crack in Ontario winters, rebar and control joints or not.
Asphalt
Budget is the main reason contractors recommend asphalt, and it’s a legitimate one. Install time is 2-3 days vs. 5-7 for interlock. It’s the right surface for properties likely to be redeveloped or sold in the next decade, or for large commercial areas where cost per square foot is the real constraint.
What a quote should say: base depth explicitly stated, compaction method noted, seal-coat timing specified. That first seal goes at year one, not at installation — asphalt needs time to cure. If those items aren’t in the quote, the estimate is a guess.
Maintenance timeline: reseal every 3-5 years, crack-fill at year 7-10, replacement at 15-20 years. Factor that into the upfront cost comparison before deciding asphalt is cheaper.
Concrete
Concrete holds up better than asphalt on sloped driveways — less heat rutting — and tends to look better longer on properties in the mid-to-upper resale range. If you want a smooth surface without the joint maintenance that interlock requires, concrete is worth pricing out.
The Ontario-specific failure mode: inadequate control joint spacing. Joints need to run every 8-10 feet to give the slab somewhere to crack that isn’t visible. Without them, the slab picks its own spot — usually diagonally across the center. Rebar doesn’t prevent this; it just keeps the pieces from separating completely.
Interlock
For curb appeal, lifespan (25-30 years with a proper install), and repairability, interlock is the strongest long-term choice for residential driveways. The failure modes and what to look for in a quote are covered in detail here: Interlock driveways and patios in Ontario: why they fail and what a good quote actually includes (2026)
One thing cost guides skip: the upgrade path runs one direction. You can convert asphalt to interlock — excavate, reuse the granular base if it’s adequate depth, lay new pavers. Going from concrete to interlock means full concrete demolition plus new interlock installation on top. If you’re undecided between concrete and interlock, that asymmetry matters.
The curb-cut permit and impervious surface rules
Replacing an existing driveway in the same footprint generally doesn’t need a permit in most GTA municipalities. Widening it, adding a second curb cut, or installing where there wasn’t a driveway before is a different situation — you need a road-cut or curb-cut permit from the municipality. City of Toronto processing runs 6-8 weeks. Starting without it gets you a stop-work order.
Several Peel and York Region municipalities now have impervious surface limits — a cap on the percentage of a lot that can be covered by non-permeable material. Permeable interlock (PICP) counts differently against those limits than standard pavers. Worth asking your contractor whether a standard install qualifies before signing anything.
If you’re working through this for a specific GTA property, post the lot conditions and what you’re replacing — contractor-side input is what this forum is for. Top contributors earn $RENO, the community reward token tied to the forum leaderboard. Claim your Solana wallet on signup: Welcome to $RENO — Quests, Rewards, Leaderboard
Regarding your post about Concrete vs. interlock vs. asphalt driveways in Ontario 2026: how contractors make the call, and what changes when frost and drainage are the real constraints — Great topic! This is something a lot of homeowners wonder about. Have you done any research or tried any approaches so far? The community here has a ton of hands-on experience — I’m sure someone’s dealt with this exact situation.
