GTA Spring 2026 Deck Staining and Refinishing: When to Strip, When to Just Coat, Stain Choice by Wood, and Real Costs
Spring is the window. Late April through early June is when most GTA decks are dry enough, warm enough, and humid enough to actually accept stain — and it is a much shorter window than most homeowners realize. The wrong week of weather, the wrong product on the wrong wood, or pushing a freshly built pressure-treated deck into a coat of stain too early are the three failures that account for the vast majority of refinishing jobs that look bad by August.
Here is the field guide we use when GTA homeowners ask whether this is the year to refinish.
When to stain in the GTA — and when to wait
The conditions that matter, in order: temperature, surface moisture, humidity, and forecast.
Temperature should sit between 10 and 30 degrees Celsius for the full 24 to 48 hours after application. Below 10 the stain will not penetrate; above 30 the surface flash-dries while the lower layers stay open, and you get a streaky, patchy finish that lifts in chips by mid-summer. The Toronto microclimate hits this band most reliably from late April through early June, then again from early September through mid-October. July and August are usually too hot in direct sun; the deck surface itself often runs 40 to 50 degrees by mid-afternoon even when the air temperature is 28.
Humidity should be under 70 percent when applied, with no rain in the 48 hours before or after. Spring humidity in the GTA tends to spike right after a rain front clears, even on a sunny day; check humidity at noon, not at 8 AM, and check the actual surface — sprinkle water on the boards, and if it beads up, the wood is still saturated and will not absorb stain.
For new pressure-treated lumber the rule is harder: the wood ships saturated with both water and chemical preservatives, and it must dry to 15 percent moisture content or lower before it will accept stain. That is typically three to six months in the GTA. A deck built in late April will rarely be ready before September; a deck built in October usually has to wait until the following summer. A moisture meter ($25 at any home improvement store) ends the guesswork. The water-bead test is a reasonable proxy if you do not have a meter. Skipping this step is the single most common cause of a stain job that fails inside a year.
Strip versus sand versus just clean
Most deck refinishing decisions come down to which one of these three you are actually buying.
A simple deck wash and stain cycle (no stripping, no sanding) is appropriate when the existing finish is intact, evenly worn, and matched to the new product you want to apply. Penetrating stains can be re-coated over compatible penetrating stains. Solid-colour stains can be re-coated over solid stains. The cycle is power-wash with a deck cleaner, let dry 48 to 72 hours, apply two coats. This is the cheapest path: roughly $1.75 to $4.50 per square foot in the GTA depending on deck complexity, railings, and stairs.
A strip-and-sand cycle is required when there is incompatible buildup (semi-transparent over solid, oil-based over water-based, or peeling layers from prior failed jobs), or when the wood has greyed and lost its top fibres to UV damage. Stripping uses a chemical wash, then power-wash and neutralization, then sanding to open the grain back up. This roughly doubles the cost — typical GTA range is $4 to $7 per square foot — but it gives the new stain something clean to bond to and resets the deck to a predictable maintenance cycle.
A full sand-only is rarely the right choice. The chemical strip plus light sand combination is faster, more thorough, and creates a more uniform surface than sanding through old finish alone.
For perspective: the same base spec of “power wash, light sand, two coats of semi-transparent oil-modified hybrid” runs roughly $1,200 to $2,400 on a 400-square-foot single-level deck with a railing — and roughly $3,000 to $5,500 if it requires a full strip first.
Stain choice by wood type
The wood you have should drive the product, not the other way around.
Pressure-treated softwood (the default for most GTA backyards) takes semi-transparent oil-modified hybrid stains best. The semi-transparent body lets the grain show but provides UV pigment; the oil-modified carrier penetrates the dense softwood; the hybrid water-component cleans up easily. Avoid full-coverage solid stains on PT unless the deck is already too far gone to show grain — the solid coat will trap moisture against the boards and accelerate cupping.
Cedar and other natural softwoods do best with translucent or semi-transparent penetrating oils. Solid stains hide the very thing that justified the cedar premium and will need to be redone every two years.
Older, greyed, or rough decks where the grain is no longer attractive are candidates for solid-colour stains, which read closer to paint and last three to five years on horizontal surfaces. This is also the right choice when the homeowner wants a specific design colour rather than a wood-tone palette.
Coverage math is consistent across product types: most deck stains cover 200 to 300 square feet per gallon on the first coat, with a second coat typically going on at half that absorption rate. A 400-square-foot deck plus railings usually needs two to three gallons. Quality semi-transparent stains run $20 to $52 per gallon at the contractor counter; solid stains run slightly higher.
Real spring 2026 GTA costs
Maintained deck, refinish only, no stripping: $1.75 to $4.50 per square foot all-in (labour + product + cleaning), depending on railings and stair complexity.
Heavily weathered deck, full strip and sand, then stain: $4 to $7 per square foot all-in.
Material-only DIY math: $80 to $200 in stain plus $30 to $80 in cleaner and applicator pads for a typical 300 to 500 square foot deck.
Add $200 to $400 if there is significant board replacement before staining. Add 20 to 30 percent for premium hardwoods that require different chemistry.
Toronto and Mississauga sit at the top of the GTA pricing range; outer 905 contractors tend to come in 10 to 15 percent lower for the same scope.
A few patterns are worth watching for this season.
The new-deck rush. Any quote that proposes staining a brand-new pressure-treated deck inside the first six weeks is a red flag. The contractor is either ignoring the moisture content reality or planning a coat that will not actually penetrate, which is effectively a cosmetic application that fails in months.
Roll-and-go application. Stain should be back-brushed after rolling on horizontal surfaces. A roller alone leaves the product sitting on the surface; back-brushing forces it into the grain. Crews that quote a tight day rate often skip this step.
Power-wash without neutralization. Chemical strippers need to be rinsed and neutralized before stain. A quote that lists “power wash” but not “deck brightener” or “neutralizer” is missing a required step.
Mid-day full-sun application in July and August. As above — the surface is too hot, the stain flash-dries, and the finish fails. A serious crew works mornings and shaded faces in summer, or pushes the schedule to September.
Stain warranty without product warranty pass-through. A two-year contractor labour warranty is meaningless if the product manufacturer warranty is voided by improper prep. Ask for the product warranty terms in writing.
When the answer is replace, not refinish
Some decks are past the point where refinishing is the right move. If more than 20 percent of the boards show splits, cupping, or rot at fasteners, if the substructure shows soft spots near posts or ledger, or if the deck is more than 20 years old and was built before current code on ledger flashing — the right move is usually replacement, not refinishing. Refinishing buys two to four years on the surface; underlying structural problems do not stop while you wait.
A short pre-refinish inspection is the single most useful $0 step a homeowner can take: pull the BBQ, walk every board, push down hard at the corners, and check the ledger flashing where it meets the house. If anything moves, anything is soft, or you can see daylight through a gap that should not be there, get a deck specialist out before you commit to a stain job.
For the related spring outdoor projects this season, a few sister threads on this forum worth reading:
Track $RENO earnings on this topic — top contributors at the homeowner-and-trades intersection are tier-up candidates, and posters who add their own GTA project photos, costs, or stain-by-wood comparisons earn quest credits when the activity engine settles them. Welcome topic for new readers: Welcome to $RENO — Quests, Rewards, Leaderboard
What did the GTA homeowners on this forum actually pay for spring deck refinishing this year? What product/wood combinations have held up in your backyard? Post the deck size, age, prep scope, and what the bottom-line invoice looked like — the more concrete the data, the more useful the thread becomes for next spring.
From LF Builders
LF Builders handles deck builds, repairs, and full exterior restoration across the GTA — and has for over 50 years. If a spring inspection turns up boards that are past staining and need replacement, see lfbuilders.ca for a licensed quote. Samm Simon is running 251 km for cancer research — real deck cost breakdowns posted to this thread earn $RENO and support the cause.
